Timing Mark on the Crank Pulley?????
Old Feb 19, 2002 | 12:12 PM
CRzex's Avatar
New User
Default Timing Mark on the Crank Pulley?????
I need help finding the timing mark on the crank pulley. I cant seem to find the mark on the pulley, is it on the outside of the pulley where the belts go? Because i found a large white dot and its located in between two of the many holes that surround the hole for for the crank pulley bolt. And also i looked in the Helms manual and it showed the timing mark on the outer part of the crank pulley and i cant seem to find anything, i was wondering if it might be different for the dx.
Any help would be appreciated thanks. By the way its 91 CRX DX. THANKS
Old Feb 19, 2002 | 12:39 PM
therealciviczc's Avatar
Default Re: Timing Mark on the Crank Pulley????? (CRzex)
It's a little notch in the edge of the pulley. If you were looking at the top surface of the belt, it would be on the edge of the pulley (the part that keeps the belt on there). You'll see it when looking straight down from the top by the engine mount, not in from the side.
Also, for timing, you're looking for the 3 marks before TDC, not the single mark that marks TDC.
suje
14
Feb 22, 2012 04:19 PM
dfabulous
10
Dec 9, 2007 11:00 PM
Jabinya
Aug 28, 2007 06:50 PM
Jorsher
Oct 11, 2004 07:40 PM
iperez
Jun 24, 2004 06:58 AM
