just got my MUGEN 26MM front sway bar. Is it a bolt on? Is it hard to install?
As the topic said, is it a direct bolt on? and what are those two bushings? where do i put those on?
any help will be ppreciated.
this thread might help you get a good look at the sway bar bushings.. https://honda-tech.com/zerothread?id=129783 but its the JDM one not mugen.
Edit- this might help you with installation. http://www.bseries.net/html/garage/swaybar.php
Also, you're seriously talking about the Front? or do you mean REAR?
[Modified by Type Goch, 1:12 PM 2/19/2002]
Did you get the 26mm rear bar as well? If you only install the 26mm front bar and run the stock 22mm in the rear that car is going to have some serious understeer... (and that is a bad thing)
