which turbo is good for the D series?
ok before anyone flame me i search the forum and found the information confusing. So i just decided to ask the question. I wanna turbo my d series but i don't know which turbo is the best. I am pretty much a noob with engine and stuff. So any information would be nice. Btw i want the complete turbo kite. After i turbo what else can i do to boost my D. Thanks in advance
It is going to take a lot of research to understand how turbos work and why they work. A great site is http://www.howstuffworks.com , the more you know the less time you'll spend on fixing it
For the d series there are a couple kits that you can get like the greddy kit or the edelbrock both of which are carb legal. There are a couple kits like the revhard ones etc that usually don't allow for a/c and p/s compatibility. I am going with a greddy kit which has a 16g turbo and can safely handle 12psi.
Research, search and ask questions
.For the d series there are a couple kits that you can get like the greddy kit or the edelbrock both of which are carb legal. There are a couple kits like the revhard ones etc that usually don't allow for a/c and p/s compatibility. I am going with a greddy kit which has a 16g turbo and can safely handle 12psi.
alright thanks again, but i search around and found this turbo kite looking pretty crazy to
me. so i'll post here and see what u guys think about it. Can i get it for less then 6.5
STAGE III (135%-140% MORE HP OVER STOCK @ 14PSI) $6499.00
CUSTOM STAGE III PRECISION T3/T04E TURBOCHARGER
CUSTOM SFP TURBO MANIFOLD
SFP DOWNPIPE
STAGE III FRONT MOUNT INTERCOOLER WITH SFP POWDER COATED PIPES
JE 9:1 LOW COMPRESSION FORGED PISTONS
CROWER BILLET CONNECTING RODS
BLOCKGUARD
ARP HEAD STUDS
HKS EXTERNAL WASTEGATE
HKS RACING BY-PASS VALVE
FMU
255 LPH IN TANK FUEL PUMP
STAGE III UPGRADED INJECTORS
APEX-i V-AFC WITH CUSTOM TUNED STAGE III FUEL MAP FROM SFP
ALL NECESSARY HARDWARE REQUIRED FOR INSTALLATION
*AVAILABLE FOR D15, D16, B16, AND B18 MODELS*
SFP DOWNPIPE
BLOCKGUARD
ARP HEAD STUDS
FMU
Honestly, you could get most of that for way under 6500. Oh and if you're running a semi-built motor why risk blowing it on a damn afc hack
. Get a p28 chipped and run something like crome or uberdata etc.
