Crx Si camshaft
Is it worth it to be installed into a DX ? am going to swap it in with the MPFI swap..... i dont know which year the camshaft came from ( is there a difference?) but am putting it into a 1990 DX crx..... Any website info on how to do it correctly ? thanks a lot for the info
http://www.geocities.com/slowmanef/d16a6cam.html
I used this when installing my zc cam, although i adjusted the valves while the engine was cold which is what it says to do in the helms. Other than that it came in handy.
Make sure you look up all the torque specs, and if you can find some helms pages on timing and adjusting the valves it will also help. (all online if you look hard enough)
