FS: Built Motor Setup (ANR,Hondata,AEBS,Skunk PRO1,JG, ARP, Comptech,STR, ETC)
Old Jul 28, 2005 | 07:50 PM
RPRacing's Avatar
Default FS: Built Motor Setup (ANR,Hondata,AEBS,Skunk PRO1,MSD ACCEL,JG, ARP, Comptech,STR, ETC)
Well, I have the Itch to go K series. I figure now is as good a time as it gets to get the most $ for my setup.
THERE IS NOTHING WRONG WITH ANY PART OF THIS SETUP. I AM SELLING TO UPGRADE TO A K SERIES.
<U>Engine setup</U>
JDM B18C Block
-Hot tanked
-Bored .010" over
-Decked .005"
B18B LS 89mm Crank
-Magnafluxed
-Hot tanked
-Polished
B18B LS Rods with ARP Rod Bolts
-Sandblasted
-Resized
JDM B18C 81.25mm ITR Pistons
USDM ITR Head
-3 Angle Valve Job
-Milled .010”
-Bronze Valve Guides
JG Engine Dynamics Springs and Retainers
Skunk 2 Pro 1 Camshafts
STR Pro Cam Gears
Comptech Intake
AEBS Intake Manifold
Hondata Intake Manifold Gasket
B&M CommandFlo Fuel Pressure Regulator
B&M Fuel Pressure Gauge
ANR Compact Header
NGK Spark Plugs
NGK Spark Plug Wires
JG Edelbrock “Piston” Oil Cap
<U>Transmission</U>
ACT Pro-lite 8lb Flywheel
ACT 6 puck clutch
2001 Integra Type R Gearbox
JDM Integra Type R Bronze Shift Linkage
JDM Integra Type R Shifter
Energy Suspension Shifter Stabilizer Bushing Set
Prothane Motor Mount Inserts
<U>ELECTRONICS</U>
MSD Digital 6 Ignition Control Unit
MSD Blaster SS External Coil
MSD 2-Step Launch Control
Boomslang OBD2a-OBD1 Wire Harness
Hondata P28 ECU
Hondata S200 with Data Logging, boost and Rom Editor (tuned for this setup)
I am trying to sell this as a whole swap. plug and play type deal. This setup is a 12 second setup in the right car. i think it will see 12s in my teg personally. i have never ran it as it sits now. last time was with only 195hp and a broken first gear, and open diff and it went 13.8 on the second run till i stopped because i had to drive home. (Vid of that Track Day)
I am asking 7000 obo. I will entertain serious offers. I need cash right now. Also looking for a comple DC5R front clip, or K series plus cash.
-Francisco
757-575-2416
I WILL ALSO INSTALL IT INTO EG/EK/DC for $300!!!
Old Jul 29, 2005 | 05:39 AM
RPRacing's Avatar
top
Old Jul 29, 2005 | 08:00 AM
RPRacing's Avatar
buy it. its quick
Old Jul 29, 2005 | 01:20 PM
Ek-CoolGuy's Avatar
Default Re: (RPRacing)
would you consider parting the header? C'mon, I'm left handed, too.
Old Jul 29, 2005 | 02:06 PM
krazie1's Avatar
BANNED
Default Re: (Ek-CoolGuy)
bump for a RHD car
Old Jul 29, 2005 | 02:39 PM
RPRacing's Avatar
as of right now. i am not parting the setup at all. (also, the avatar says "lefties do it right, (but righties do it better)" )
thanks guyes
Old Jul 29, 2005 | 03:02 PM
thermal's Avatar
Old Jul 29, 2005 | 05:20 PM
RPRacing's Avatar
thanks.
Old Jul 29, 2005 | 09:32 PM
RPRacing's Avatar
Default Re: FS: Built Motor Setup (RPRacing)
top
Old Jul 29, 2005 | 10:31 PM
jayspec22's Avatar
ttt for the special K
Old Jul 30, 2005 | 01:38 AM
Ek-CoolGuy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPRacing &raquo;</TD></TR><TR><TD CLASS="quote">as of right now. i am not parting the setup at all. (also, the avatar says "lefties do it right, (but righties do it better)" )
thanks guyes</TD></TR></TABLE>
LOL diss
Old Jul 30, 2005 | 03:30 AM
RPRacing's Avatar
haha top
Old Jul 30, 2005 | 10:06 PM
RPRacing's Avatar
top
hkwe36
Oct 11, 2010 07:29 AM
BoBo Racing
Jan 21, 2008 04:52 PM
BoBo Racing
Jan 14, 2008 12:30 PM
Viorent Grip! EG
Sep 17, 2007 08:11 AM
ALL MOTA
Nov 21, 2004 11:03 AM
