Passenger Side Lightning Issues
This is quite weird and starting happening after I installed my new headlamps. My left side signal bulb and main bulb are significantly dimmer than the right side. Also, ONLY when my lights are on my turn signal will not work, but the green light in the cluster is semi(?) lit up. If i put my lights off or have just the signal bulbs on, everything is fine. Only when I have all lights on is when everything on the left side is dim and the left signal is not working. I do not know about my rear light, but I think they are fine.
Any ideas?
Any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunY »</TD></TR><TR><TD CLASS="quote">It might be the lighting relay that's bad. If not....Fuses. The last thing to check is the wiring, if was damaged or not.</TD></TR></TABLE>
Its not the fuses, and as far as wiring, I have checked as much as I could and everything looks good. Where is the lighting relay located? Underhood Fuse Box?
Project Mighty Knight
Nov 30, 2003 09:52 AM
