bad idle, cel, HELP
Old Jul 28, 2005 | 06:05 PM
RFd15bhatch's Avatar
Default bad idle, cel, HELP
I have a 2000 civic si. i unplug the battery the car runs fine for about 20 minutes.a cel comes on it is the idle control. The car is really jerky when i give it gas. I bought a new idle air control valve. The car does the same thing the rpms pulse from 1000 to 2000. What else could this be. i need help bad.
Thanks
Old Jul 28, 2005 | 06:09 PM
northkai3's Avatar
Default Re: bad idle, cel, HELP (RFd15bhatch)
sounds like a loose vacuum hooooooooose!
Old Aug 22, 2005 | 03:40 PM
knoj's Avatar
I had this problem just today... New plugs, wires, and reset the CEL. Good to go.
99 Si.
Old Aug 22, 2005 | 03:42 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: bad idle, cel, HELP (knoj)
The possibilites to this are endless... check for a vaccum leak first though.
Old Aug 22, 2005 | 03:52 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: bad idle, cel, HELP (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">The possibilites to this are endless... check for a vaccum leak first though. </TD></TR></TABLE>Vac leak or if he is throwing a code for the IACV it is most likely in the wiring.
joshua89
Aug 20, 2011 01:47 PM
zenon8890
Mar 30, 2010 04:18 AM
theshamgod
Mar 25, 2009 08:18 AM
rlwturbosi
Aug 7, 2005 05:44 PM
TheAutoboxer
Nov 1, 2003 06:46 AM
