99 Accord alarm keeps tripping. Why??
Old Jul 28, 2005 | 06:00 PM
BigOz's Avatar
Default 99 Accord alarm keeps tripping. Why??
'99 Accord EX with factory alarm. Alarm keeps going off without anything obvious triggering it (only happens when the car is locked, of course). In other words, it'll be sitting quietly, then the alarm triggers for no apparent reason. This just started a few months ago - never had a problem in the 5+ years I've owned the car. It happens intermittently, but more frequently as of late.
I've tested and ruled out both keyless remotes. Battery level indicates charged, although I haven't had it tested.
1 mechanic thought it was a bad sensor, or possibly a wiring short. Another said it could be the computer, and suggested a visit to the dealer.
Any suggestions? I can't keep leaving my car unlocked!
Old Jul 28, 2005 | 10:03 PM
CmptchAV6's Avatar
Default Re: 99 Accord alarm keeps tripping. Why?? (BigOz)
I would check the door closed switches first, other than that it could be the lock switches as the alarm in the accord goes off if you unlock the door from the inside of the vehicle when it is locked.
Old Jul 29, 2005 | 06:52 AM
Pairallel's Avatar
Check hood and trunk switches - may need to be cleaned / lubricated...
Old Jul 29, 2005 | 06:59 AM
THEROPE's Avatar
Default Re: (Pairallel)
sounds like a short
Old Jul 29, 2005 | 09:50 AM
Lowski's Avatar
Does the car still have the origianl battery installed? Could be going bad. Just an idea.
FYI, you can lock the doors with the door switches instead of the remotes. This locks the door, but doesn't turn on the alarm. At least that is how it works on my 99 accord LX with the OEM alarm/keyless system installed.
Good Luck, Chris
cruise
Mar 15, 2011 09:40 PM
Danny.T
Aug 25, 2010 10:36 AM
Bes
Oct 24, 2006 11:34 AM
Shinbo
Dec 13, 2004 03:02 AM
