Main Relay???
Old Jul 28, 2005 | 05:55 PM
ratbelly's Avatar
Default Main Relay???
I have a 1993 Honda Accord. Can anyone tell me where the MAIN RELAY is in it? My car does not start often times and I believe this is the problem. How do I check to see if that is the problem?
Thank you
ratbelly
Old Jul 28, 2005 | 06:44 PM
dew80362's Avatar
Default Re: Main Relay??? (ratbelly)
it underneath the drivers dash on the left side if your looking at. if your underneath the dash it'll be on your right all the way up. It's a 7 pin connector I believe.
Old Jul 28, 2005 | 06:54 PM
Tha Colonel's Avatar
Default Re: Main Relay??? (dew80362)
yeah he is right i had to change mine cause mine was doing the same thing that yours was you can get one from a junk yard for about 5 or 10 dollars so good luck
john
Old Jul 28, 2005 | 08:08 PM
hondadude's Avatar
As you are laying on your back looking up under the dash, the main relay is above the cruise control unit[needs to be removed] to the right of the steering column...you will see the bottom of it where the wire plug is. The box is about 3"X 1 1/2" Gray color and will have "MITSUBA RZ00??" printed on the side of it. You can pop the guts out of the box with a pocket screwdriver, check the small relay coil solder joints on either end of the circuit board for cracks.
Old Jul 29, 2005 | 06:17 AM
deserthonda's Avatar
Default Re: Main Relay??? (hondadude)
relay is on the left of steering color. it has 7 wires going to it the bottom which is the part that u will see is rusty/brownish and yes like the dude says you need to remove cruise control unit box if so equipped
Old Jul 29, 2005 | 12:54 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Main Relay??? (deserthonda)
grab a haynes, it will tell you how to troubleshoot it to see if that is the prob.
Old Jul 29, 2005 | 07:12 PM
Default Re: Main Relay??? (Vt4cPwn35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 &raquo;</TD></TR><TR><TD CLASS="quote">grab a haynes, it will tell you how to troubleshoot it to see if that is the prob. </TD></TR></TABLE>
dont get an haynes book if you need to get a service manual get a helm service manual it is the same honda dealers use much much better than haynes
deadhead23
Jan 15, 2021 10:43 AM
sidewayz32
14
Nov 12, 2005 06:40 AM
Backk InTheDA
Sep 28, 2005 03:29 PM
RLOWE
Aug 1, 2004 10:30 AM
monalisa overdrive
Jun 16, 2004 10:11 PM
