ANOTHER Overheating prob.....very weird....but please read! STUMPED!!!
Old Jul 28, 2005 | 04:21 PM
doublek's Avatar
Default ANOTHER Overheating prob.....very weird....but please read! STUMPED!!!
Ok guys i know everyone is sick and tired of seeing another overheating thread but this one might be a lil dif. Possibly cracked CYLINDER HEAD?
Well since it was overheating i decided i need to make sure its fixed so i decided i was gonna put a lil more with it. So i went out got some full race traction bars put the new EG rad in it with new slim fan. Replaced the water pump, thermostat, rad cap, thermo sensor, and throughly cleaned the system. I also did a compression and leak down test. ALL GOOD. Compression was about 270 on all 4 cylinders and and leak down was no more than 8% on all 4 cylinders. I then bleed the system with heat on full blast extremly well about 2 times about 30 min a piece Well i thought this was def going to fix my overheating isssue. WRONG. The bastard still overheating. Its advadently building pressure somewhere becuase it fills the resivor completly up.
My heat only comes out sometimes but when it blows out cold air then it overheats. As soon as the heat blows again it begins to cool down. So obviosuly theres air in the system which causes no heat to come out when the air passes threw the heater core. THATS MY OPINION!!
So to sum it up i cant figure out what the crap is going on. Do you think theres a possible crack in the cylinder head causing air to get into the system? Thats the only thing that can be left. PLEASE HELP!!!!!
THANKS!!!
Modified by doublek at 7:34 PM 7/28/2005
Old Jul 28, 2005 | 04:50 PM
GDR888's Avatar
Default Re: ANOTHER Overheating prob.....very weird....but please read! STUMPED!!! (doublek)
How about the head gasket?
Old Jul 28, 2005 | 04:55 PM
doublek's Avatar
Default Re: ANOTHER Overheating prob.....very weird....but please read! STUMPED!!! (GDR888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GDR888 &raquo;</TD></TR><TR><TD CLASS="quote">How about the head gasket?</TD></TR></TABLE>
Head gasket should be fine since i did the compression test which showed all cylinders at about 270psi. And leak down test was about 8% on all cylinders.
I guess it still a possibility. But highly unlikely. No oil in coolant or visa versa.
Old Jul 28, 2005 | 04:57 PM
Preferio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublek &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by doublek at 7:34 PM 7/28/2005</TD></TR></TABLE> If it does that, heats blows warm air, and it cools down, then air is cool, it heats up.. it kind of sounds like the thermostat is opening and closing for no apparent reason..
Old Jul 28, 2005 | 05:00 PM
doublek's Avatar
Ive also changed the thermostat twice. Becuase i have heard of them being bad right out of the box. I just got the OEM replacement.
Old Jul 28, 2005 | 05:01 PM
Preferio's Avatar
Default Re: (doublek)
then.. i'm going to have to say you have a pocket of air in the system..
Old Jul 28, 2005 | 05:05 PM
doublek's Avatar
What would be causing that to happen? Besides a cracked cylinder head?
Old Jul 28, 2005 | 06:58 PM
doublek's Avatar
someone has to know or have had a this problem.....i cant be the first.....
Old Jul 29, 2005 | 05:55 AM
doublek's Avatar
bump
Old Jul 29, 2005 | 06:58 AM
b204dr's Avatar
run a pressure test on your cooling system-
problem 1 - thermostat-
problem 2 - waterpump
problem 3- air pockets
problem 4-head gasket
problem 5-cracked block( car most likly wouldnt run)
answer it enough check each one in that order and problem will be discovered
boostin99em1
14
Jun 7, 2016 08:43 PM
doublek
17
Jul 31, 2005 02:29 PM
doublek
Jul 31, 2005 09:23 AM
doublek
Jul 29, 2005 06:33 AM
