better cooling fans
Old Jul 28, 2005 | 03:40 PM
stevescivic's Avatar
Default better cooling fans
anyone here know of a factory direct fit drop in replacement fan that flows a lot more air than the stock one? The problem I have with my 92 civic hatch is that it has a type R swap with jasma headers and its running so hot that my engine begins to run poorly and my a/c doesn't work right either b/c the condenser isn't able to cool the refrigerant properly.
the fan MUST directly bolt in and flow at least 30% more than stock and have the same degree of reliability as my stock honda fan.
Recommendations?
Thanks
Old Aug 3, 2005 | 09:51 PM
SI_SOLDIER's Avatar
Default Re: better cooling fans (stevescivic)
I did a H22 swap and I couldn't drive more than 5 minutes on the freeway without it over heating. I put in a FAL thin rail fan with a basic dual rail radiator and it never hit the half way mark on the temp gauge again. Hope that helps.
chrisfromsrq
Feb 10, 2010 01:06 PM
1baddturbosi
Jun 28, 2008 08:31 PM
huge230
Jul 31, 2005 08:55 AM
keebler65
Mar 18, 2002 02:35 PM
Halo
Jun 15, 2001 12:04 PM
