B16B ROD LENGTH! *SEARCHED*
I've been trying to see if I can get a definitive answer on how long the B16B rods really are. I searched and it seems that whenever this was asked the answer is always "longer" or something to that effect.
If someone could please help me out, I would appreciate it mucho grande.
Stock Compression:
B16A 10.2:1 (1ST GEN)
B16A 10.4:1 (2ND GEN-UP)
B17A1 9.7:1
B18C1 10.0:1 (USDM)
B18C1 10.6:1
B18C5 10.6:1 (USDM)
B18C5 11.1:1 (JDM)
B16B 10.8:1
B18A1 9.2:1
B18B1 9.2:1
B18B 9.4:1 (JDM)
B20B 8.8:1 (USDM/JDM)
B20Z 9.6:1 (USDM/JDM)
D16A1 9.5:1
D16Z6 9.1:1
D16Y8 9.6:1
ZC 9.5:1
Engine Piston Mixing Compression output:
B16A W/ B16B(PCT) PISTONS YEILD 11.1:1
B16A W/ B18C5 (P73-A0) PISTONS YEILD 10.4:1
B16A W/ B18C5 (P73-00) PISTONS YEILD 10.7:1
SAME ORDER FOR THE REST
B17A1 11.4
B17A1 10.6
B17A1 10.8
B18C1 11.8:1
B18C1 10.9:1
B18C1 11.4:1
Piston/Rod Measurements:
B16A PR3:
ROD LENGTH: 5.290”
STROKE: 3.031”
BORE SIZE: 3.189 “(81MM)
COMPRESSION HEIGHTS: 1.180”
DOME HEIGHT: .098”
WEIGHT: 299 GRAMS
B17A1 P61:
ROD LENGTH: 5.208”
STROKE: 3.205”
BORE SIZE: 3.189” (81MM)
COMPRESSION HEIGHTS: 1.181"
DOME HEIGHT: CAN’T FIND YET
WEIGHT: CAN’T FIND YET
B18A1 PR4:
ROD LENGTH: 5.394”
STROKE: 3.504”
BORE SIZE: 3.189“ (81MM)
DOME HEIGHT: -.055”
WEIGHT: 280 GRAMS
B18C1 P72
ROD LENGTH: 5.429”
STROKE: 3.433”
COMPRESSION HEIGHTS: 1.183”
DOME HEIGHT: .000”
WEIGHT: 305 GRAMS
B18C5 P73-A0
ROD LENGTH: 5.429”
STROKE: 3.433”
COMPRESSION HEIGHTS: 1.190”
DOME HEIGHT: .070”
WEIGHT: 310 GRAMS
B20B
ROD LENGTH: NA
STROKE: NA
BORE SIZE: 3.307” (84MM)
COMPRESSION HEIGHTS: 1.165”
DOME HEIGHT: -.035”
WEIGHT: 312 GRAMS
H22A
ROD LENGTH: 5.63”
STROKE: 3.571”
BORE SIZE: 3.425” (87MM)
COMPRESSION HEIGHTS:1.222"
DOME HEIGHT: NA
WEIGHT: NA
H23A1
ROD LENGTH: 5.571"
STROKE: 3.740"
BORE SIZE: 3.425" (87MM)
COMPRESSION HEIGHTS: 1.203"
DOME HEIGHT:NA
WEIGHT: NA
D15B1/ 2/ 7/ 8
ROD LENGTH: 5.275”
STROKE: 3.326”
BORE SIZE: 2.933” (74.5MM)
COMPRESSION HEIGHTS: 1.208”
DOME HEIGHT: .000”
WEIGHT:
D16Z6
ROD LENGTH: 5.393”
STROKE: 3.543”
BORE SIZE: 2.952” (75MM)
COMPRESSION HEIGHTS: 1.181”
DOME HEIGHT: -.118”
WEIGHT:NA
D15Z1
ROD LENGTH: 5.393”
STROKE: 3.326
COMPRESSION HEIGHTS: 1.092”
DOME HEIGHT: -.277”
WEIGHT:NA
D16Y7
ROD LENGTH: 5.393”
STROKE: 3.543”
DOME HEIGHT: -.130”
WEIGHT:NA
D16Y5
ROD LENGTH: 5.393”
STROKE: 3.543”
COMPRESSION HEIGHTS: 1.161”
DOME HEIGHT: -.106”
WEIGHT:NA
D16Y8
ROD LENGTH: 5.393”
STROKE: 3.543”
DOME HEIGHT: -.083”
WEIGHT:NA
D17A1
ROD LENGTH: 5.511”
STROKE: NA
COMPRESSION HEIGHTS: 1.062”
DOME HEIGHT: -.106”
WEIGHT:NA
D17A2
ROD LENGTH: 5.511”
STROKE: NA
DOME HEIGHT: -.104”
WEIGHT:NA
ROD TECH:
ROD/STROKE RATIO AND ROD LENGTH:
B16A: 1.74/ 134MM
B17A1: 1.62/131.87MM
B18A1: 1.54/ 137MM
B18B: 1.54/137MM
B18C1: 1.58/137.9MM
B18C5: 1.58/137.9MM
B20A3/5 3RD GEN LUDE) 1.50/142.75MM
B21A1: 1.492/141.7MM
B20B: 1.539/137MM
H22A: 1.577/143MM
H23A1: 1.49/141.5MM
F20C: 1.821/153MM
D17A1: /140MM
D17A2: /140MM
D16Y8: 1.52/137MM
D16Y7: 1.52/137MM
D16Z6: 1.52/137MM
D16A1: 1.52/137MM
D16A6: 1.52/137MM
D15B1: 1.59/134MM
D15B2: 1.59/134MM
D15B7: 1.59/134MM
D15B8: 1.59/134MM
ZC: 1.52/137MM
b16b is same as b16a
B17A1 9.7:1
B18C1 10.0:1 (USDM)
B18C1 10.6:1
B18C5 10.6:1 (USDM)
B18C5 11.1:1 (JDM)
B16B 10.8:1
B18A1 9.2:1
B18B1 9.2:1
B18B 9.4:1 (JDM)
D16A1 9.5:1
D16Z6 9.1:1
D16Y8 9.6:1
ZC 9.5:1
B17A1 11.4
B17A1 10.6
B17A1 10.8
B18C1 11.8:1
B18C1 10.9:1
B18C1 11.4:1
B16A PR3:
ROD LENGTH: 5.290”
STROKE: 3.031”
DOME HEIGHT: .098”
WEIGHT: 299 GRAMS
B17A1 P61:
ROD LENGTH: 5.208”
STROKE: 3.205”
B18A1 PR4:
ROD LENGTH: 5.394”
STROKE: 3.504”
DOME HEIGHT: -.055”
WEIGHT: 280 GRAMS
B18C1 P72
ROD LENGTH: 5.429”
STROKE: 3.433”
DOME HEIGHT: .000”
WEIGHT: 305 GRAMS
B18C5 P73-A0
ROD LENGTH: 5.429”
STROKE: 3.433”
DOME HEIGHT: .070”
WEIGHT: 310 GRAMS
B20B
ROD LENGTH: NA
STROKE: NA
DOME HEIGHT: -.035”
WEIGHT: 312 GRAMS
H22A
ROD LENGTH: 5.63”
STROKE: 3.571”
DOME HEIGHT: NA
WEIGHT: NA
H23A1
ROD LENGTH: 5.571"
STROKE: 3.740"
DOME HEIGHT:NA
WEIGHT: NA
D15B1/ 2/ 7/ 8
ROD LENGTH: 5.275”
STROKE: 3.326”
DOME HEIGHT: .000”
WEIGHT:
D16Z6
ROD LENGTH: 5.393”
STROKE: 3.543”
DOME HEIGHT: -.118”
WEIGHT:NA
D15Z1
ROD LENGTH: 5.393”
STROKE: 3.326
DOME HEIGHT: -.277”
WEIGHT:NA
D16Y7
ROD LENGTH: 5.393”
STROKE: 3.543”
DOME HEIGHT: -.130”
WEIGHT:NA
D16Y5
ROD LENGTH: 5.393”
STROKE: 3.543”
DOME HEIGHT: -.106”
WEIGHT:NA
D16Y8
ROD LENGTH: 5.393”
STROKE: 3.543”
DOME HEIGHT: -.083”
WEIGHT:NA
D17A1
ROD LENGTH: 5.511”
STROKE: NA
DOME HEIGHT: -.106”
WEIGHT:NA
D17A2
ROD LENGTH: 5.511”
STROKE: NA
DOME HEIGHT: -.104”
WEIGHT:NA
ROD TECH:
B16A: 1.74/ 134MM
B18A1: 1.54/ 137MM
B18B: 1.54/137MM
B18C1: 1.58/137.9MM
B18C5: 1.58/137.9MM
B20B: 1.539/137MM
H22A: 1.577/143MM
H23A1: 1.49/141.5MM
F20C: 1.821/153MM
D17A1: /140MM
D17A2: /140MM
D16Y8: 1.52/137MM
D16Y7: 1.52/137MM
D16Z6: 1.52/137MM
D16A1: 1.52/137MM
D16A6: 1.52/137MM
D15B1: 1.59/134MM
D15B2: 1.59/134MM
D15B7: 1.59/134MM
D15B8: 1.59/134MM
ZC: 1.52/137MM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZC1.8crx »</TD></TR><TR><TD CLASS="quote">
b16b is same as b16a </TD></TR></TABLE>
Wrong.
The b16b has the same stroke length of the b16a but with a 7mm taller block. Add 7mm to the b16a rods and you have the b16b rod length. I just wanted you guys to do a little thinking for yourselves.
Wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch »</TD></TR><TR><TD CLASS="quote">
Wrong.
The b16b has the same stroke length of the b16a but with a 7mm taller block. Add 7mm to the b16a rods and you have the b16b rod length. I just wanted you guys to do a little thinking for yourselves.</TD></TR></TABLE>
Are the wrist pins located at the exact same height for both the B16a/b pistons? If not, that would mean that some of the rod length would be made up by piston height (just asking since I don't know myself).
Wrong.
Actually it is not, the compression height is taller, the reason the deck height is different when using that piston in other B engines. I have not measured one but the rod length seem to be approx. 143mm.
[french] Yez, zey do pop out of ze hole a littal bit on ze b16a'z with CTR pistones[/french]
I was just trying to simplify it.
How much would you say the compression height differs from a set of ITR's?
is3oo
13
Aug 19, 2001 11:09 PM
