p72 or p28
Old Jul 28, 2005 | 03:09 PM
hYbRid_Eg6's Avatar
Default p72 or p28
i want to do a obd2 to obd1 conv., i have a 2000 gsr, my friend is selling his obd 1 ecu, and it is a p28 ecu, will it make a difference what ecu im running? im new to all this, i see that other people are running p72 ecu, whats the difference? will my car throw a cel after the obd1/obd2 conv? will my car run better or stay the same?need some info. thanks
Old Jul 28, 2005 | 04:16 PM
lsvtecracer's Avatar
Default Re: p72 or p28 (hYbRid_Eg6)
You'll need to get a obd2 to obd1 jumper harness. For the p28 ecu to work, you'll need to get it chip with a p72 program for it to run without throwing a cell.
Old Jul 28, 2005 | 09:58 PM
mtber's Avatar
Your car is not going to run better with a stock p72 ecu.
Look into an aftermarket intake manifold such as skunk2/aebs along with a chipped obd1 ecu.
Old Jul 30, 2005 | 02:09 PM
hYbRid_Eg6's Avatar
Default Re: p72 or p28 (mtber)
well i wanted to go turbo in the furture, what do i do then? still get the ecu and still leave it stock or get it chipped anyways with the p72 program, but if i go all motor can i just send the p28 ecu to hondata and have them program it.
Old Jul 30, 2005 | 05:14 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hYbRid_Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">well i wanted to go turbo in the furture, what do i do then? still get the ecu and still leave it stock or get it chipped anyways with the p72 program, but if i go all motor can i just send the p28 ecu to hondata and have them program it.</TD></TR></TABLE>
Get an ecu chipped for your current setup, then you decide to go turbo then your ecu will already be chipped ready for honda/crome/uberdata etc.
Old Jul 31, 2005 | 03:20 PM
Educator's Avatar
If you are going turbo and you wish to run Hondata, get a 94-95 GSR p72 ecu. You will be converting to OBDII and you will retain the ability for the ecu to pull timing via the knock sensor. A p28 does not have this function.
Old Jul 31, 2005 | 09:36 PM
hYbRid_Eg6's Avatar
Default Re: p72 or p28 (Educator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Educator &raquo;</TD></TR><TR><TD CLASS="quote">If you are going turbo and you wish to run Hondata, get a 94-95 GSR p72 ecu. You will be converting to OBDII and you will retain the ability for the ecu to pull timing via the knock sensor. A p28 does not have this function.</TD></TR></TABLE>
so i have to get a p72 ecu(obd1), why will i be converting to obd2?even if im converting to obd1 with my harness?
MurtazaDSM
Engine Management and Tuning
Dec 23, 2010 08:25 PM
RIPPO
Dec 7, 2007 08:38 PM
Mhollaek9
Jun 23, 2007 07:21 PM
PreludeSiTdriver
Oct 26, 2004 03:35 PM
