Air/Fuel and Oil Pressure gauges help
Old Jul 28, 2005 | 02:46 PM
DohctorVtec's Avatar
Default Air/Fuel and Oil Pressure gauges help
I just got a Air Fuel and Oil Pressure gauge + pod for free from my friend but dont really know if they are good or not the Air Fuel gauge the brand is Faze do any of you got those if so are they good and the Oil Pressure is Ractive are those good? and I also need to know what sensors I need to hook them botrh up and how much they cost thanks
Old Jul 28, 2005 | 06:33 PM
specv5150's Avatar
Default Re: Air/Fuel and Oil Pressure gauges help (DoctorVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoctorVtec &raquo;</TD></TR><TR><TD CLASS="quote">I just got a Air Fuel and Oil Pressure gauge + pod for free from my friend but dont really know if they are good or not the Air Fuel gauge the brand is Faze do any of you got those if so are they good and the Oil Pressure is Ractive are those good? and I also need to know what sensors I need to hook them botrh up and how much they cost thanks</TD></TR></TABLE>
I say not install them if you dont have any mods done to your car. The AF is useless anyway. The oil pressure CAN serve a purpose but again if your car is stock, why bother other than to look cool?. If it is electric, you will need the sender. If it is manual, you will need to run a line from the tapped location to the gauge. You can either tee off the oil pressure sending unit or the oil filter with a sandwich.
Old Jul 28, 2005 | 07:30 PM
Default Re: Air/Fuel and Oil Pressure gauges help (specv5150)
My car isnt stock have a B16 with ITR internals port and polished bored throttle body just thought I would throw them in because I got them for free but since 3 people have said they are a waste ill just sell them thanks
Old Jul 28, 2005 | 08:57 PM
blackeg's Avatar
use the oil gauge, and throw the a/f gauge out (or sell it). i cant tell you how many times ive had my wideband reading much leaner than stoich and my a/f gauges sitting on rich. they dont work
Old Jul 28, 2005 | 09:19 PM
Default Re: Air/Fuel and Oil Pressure gauges help (blackeg)
Ill have to get the sending unit for the oil one then but I heard from someone that the oil sending unit can **** up your block?
Old Jul 28, 2005 | 10:00 PM
cambopheonix56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoctorVtec &raquo;</TD></TR><TR><TD CLASS="quote">Ill have to get the sending unit for the oil one then but I heard from someone that the oil sending unit can **** up your block?</TD></TR></TABLE>
well with hi revving motors, if you mound it strait to the block, you run the risk of it comming loose from the vibrations.
Old Jul 28, 2005 | 10:57 PM
hondaeg8's Avatar
Default Re: Air/Fuel and Oil Pressure gauges help (cambopheonix56)
why would you risk the fitting coming lose and you won't risk the oil pressure sensor coming lose?
i would think the fitting for the oil pressure guage would be lighter than the oil pressure sensor thats on there now.
this is... that you don't use the oil pressure sensor anymore.
b18 hatch mike
Mid-Atlantic (Sales)
Jan 1, 2008 05:34 PM
UnderGroundConcepTS
Sep 30, 2004 01:12 PM
rjay8604
Jun 29, 2004 02:34 PM
realfasthonda
Mar 4, 2004 11:05 PM
sporkcrx
Oct 10, 2003 09:28 AM
