O2 sensor question
Old Jul 28, 2005 | 02:26 PM
bmheck5184's Avatar
Default O2 sensor question
I haven't been around Hondas for a while, so this may be a dumb question (yes I tried searching) but a guy on a local board I am on is having some o2 problems. Can a five wire 02 sensor work on an EF? Just connect the hot wire and the ground? I have more experience with obd2 equipped cars/emissions, so I just thought I would pick H-T's brain instead. Thanks in advance guys.
Old Jul 28, 2005 | 02:31 PM
dr_latino999's Avatar
Default Re: O2 sensor question (bmheck5184)
A five wire Oxygen sensor is out of a VX correct? Which means it would be a wideband Oxygen sensor of sorts. And if so, try to hook up as many of the wires as possible -
Oxygen Content - Hook up to stock wire
Ground - Thermostat Housing
Oxygen Heater - Ignition On 12V
Fifth Wire - ???
Old Jul 28, 2005 | 08:00 PM
Bunger's Avatar
Default Re: O2 sensor question (dr_latino999)
The output voltage of the VX O2 sensor is not the same as a 1 wire or 4 wire (heated) O2 sensor. Unless you are using a controller and do some sort of datalogging, I would stick to the factory style O2.
Old Jul 28, 2005 | 08:26 PM
Default Re: O2 sensor question (Bunger)
So it uses a full 5 volt range instead of the standard 1 volt?
Old Jul 28, 2005 | 09:32 PM
Bunger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">So it uses a full 5 volt range instead of the standard 1 volt?</TD></TR></TABLE>
It uses a range of about 1.4V (10:1) to about 2.90V (20:1), with about 2.5V being around 14.7:1... much different than a standard narrow band O2.
Old Jul 28, 2005 | 11:05 PM
bmheck5184's Avatar
well the guy bought the car with a 5 wire....any way to actually make it work correctly (without further investment) or should he just buy a 2 wire and call it a day?
Old Jul 29, 2005 | 05:20 AM
He should just purchase a one-wire replacement and call it a day.
BLJ-93eg
Apr 27, 2007 02:03 PM
1.8
Mar 29, 2006 10:30 PM
