MPFI help needed ASAP
i'm in the middle of my B16 swap and i need to know if there's (2) extra pins on the ecu plugs that are not being used so i can use them on my fuel injector wiring. I had my old ecu clips w/ wire but it got thrown out BY ACCIDENT. If anyone knows of any 2 pins that are not needed that i can use for the fuel injectors, that would be a great help
BTW...its a 91 STD hatch w/ B16
thanx
mike
thanx
mike
-Pins B10 and B12 are empty meaning there are no wires going into them as a general rule, however some models have a wire at B12 (if you have one that is one there that is one less wire you will need to move).
-Pins B2 and B11 have wires going into them but they are not used for anything on most cars (see Automatics and Exceptions above).
-Take the pin/wire from B2, de-pin it (this means pop it out of the plug) and pin it (pop it into plug) into B10's empty spot, how you have a wire at B10.
-Take the pin/wire from B11, de-pin it and clip it into the B12 spot, now you have a wire at B12.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">Dr Latino, the answer meister.
</TD></TR></TABLE> That's a new one
AdamITR
May 14, 2003 05:44 PM
