H22 swap what ecu?
I am droping an h22 in my 96 2door acoord an i was wondering is i should put a GSR ecu in it because it has a higher rev limiter but im not sure if it will be runing the motor the way it should. so what would be the better way to go an what are some of the pros an con between the normal h22 ecu and the gsr ecu>?
i would keep the h22's ecu there is no problem with it and it always can be reprogrammed. i have one in my car with a turbo pushing 12 psi and i havent had problems yet.
