Need opinions, B or K series
Old Jul 28, 2005 | 10:10 AM
egb18c5's Avatar
Default Need opinions, B or K series
I'm trying to build an all motor, daily driven 12 sec motor, so that means i'm not even thinking about going nitrous for the extra horses. i'm debating whether i should go B series or K to reach 12's. I have a 99 ex by the way.
I just need some opinions on what you guys would do, i know the advantages of both and i done my research but i just need some opinions. what do you guys think you will do if you had to choose between them.
o and by the way, i'm not lookin into frankensteins yet but if i have to i will, thanks.
Old Jul 28, 2005 | 10:16 AM
fastacura99's Avatar
good luck. (I hope that helps)
Old Jul 28, 2005 | 10:38 AM
92Jspec's Avatar
Default Re: Need opinions, B or K series (egb18c5)
if money isn't an issue i'd say go with the Kseries.
Old Jul 28, 2005 | 10:43 AM
JerseySiPOS's Avatar
Default Re: Need opinions, B or K series (92Jspec)
If your goal is 12s, i would just go with a stock bore B18 whether LSvtec, gsr or itr. It's been proven over and over again, that this platform can reach that goal. And that's with stock pistons and even ctr cams and tuning.
Old Jul 28, 2005 | 12:02 PM
chunky's Avatar
with cams for the k20a3 coming out, you will be able to have a budget k-series build as the a3 motor is less than half the cost of the k20a2 motor in most cases and will still outperform a b18.
Old Jul 28, 2005 | 12:05 PM
Professor15's Avatar
Default Re: (chunky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunky &raquo;</TD></TR><TR><TD CLASS="quote">with cams for the k20a3 coming out, you will be able to have a budget k-series build as the a3 motor is less than half the cost of the k20a2 motor in most cases and will still outperform a b18.</TD></TR></TABLE>It really depends on your budget. But a Nice k20a3 with a k24 block would do wonders with the proper headers n tuner.
BrianB16A2
K Series
37
Jan 18, 2014 07:16 PM
kenny7231
Jan 9, 2008 08:23 PM
HFP-EP3
Nov 25, 2007 10:11 AM
Slo Honda Driver
Aug 16, 2005 01:59 PM
