ITR suspension bars- Question
I want to buy a set of ITR suspension bars from a 2000 minus the upper front strut bar. One guy said $75 shipped. What exactly am I getting and is it worth it for my LS. WIll it fit, or are extra parts necessary for a correct fit. Tanx.
is the lower sway the same as the one that goes in the trunk/hatch?
what is the one that goes in front under the hood, not the upper strut
rear lower sway bar is NOT the same one that goes in the Trunk. The one youre referring to might be the rear upper strut bar but the USDM ITR's did NOT come with one. Either that or that other bar in the rear of the Hatch. The bar that goes under the hood is the Front Upper Strut Bar, nothing else.
well the one directly under the hood in the front is the front upper strut bar....the one on the front under the engine is the front lower tie bar and the one connecting the front lower control arms is the front lower sway bar
