Will 95 civic Test pipe/cat fit on a 98 Integra RS?
Old Jul 28, 2005 | 09:09 AM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Will 95 civic Test pipe/cat fit on a 98 Integra RS?
I posted this in the integra forum, no help, so maybe someone in here knows. Thanks
Old Jul 28, 2005 | 09:15 AM
cxSHOE's Avatar
Default Re: Will 95 civic Test pipe/cat fit on a 98 Integra RS? (rukawa1one)
92-95 civic hatch cat is 15.5 inches long.
92-95 civic coupe is 17" same as integra
but the area that connects to collector donut on the 15.5 inch and 17" are turned different. so i dont think it will work. so unless your using an integra header it may not work.
Old Jul 28, 2005 | 09:19 AM
rukawa1one's Avatar
well the part is from a 95 EX, and the actual car that we want to put it on is a 98 RS, so yes the motor is an b18b in an integra chassis
Old Jul 28, 2005 | 09:54 AM
cxSHOE's Avatar
ok yea your cat should be 17" long which it should fit, but i think the civic and integra cat collector holes will be turned differently. so the length will be fine, but the bolt pattern of the civic cat wont work with the integra header at the collector.
Old Jul 28, 2005 | 10:46 AM
rukawa1one's Avatar
Default Re: Will 95 civic Test pipe/cat fit on a 98 Integra RS? (cxSHOE)
Thanks for the info
Old Jul 28, 2005 | 11:47 AM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info </TD></TR></TABLE>
np if worst comes to worse just have a muffler shop cut and reweld the flange on the cat.. i had it done so i know it can work perfectly fine with your set up as well.
TehMan
Jan 20, 2006 09:10 AM
bonylad
Sep 26, 2005 01:25 PM
MenaceL.A.671
Oct 4, 2004 04:39 AM
slowsleeper
Aug 26, 2004 08:59 AM
