What does piston overbore mean?
Old Jul 28, 2005 | 06:40 AM
crxowner's Avatar
Default What does piston overbore mean?
what is piston overbore? someone is selling a set of ctr pistons with a .25 overbore and i need to know if they will fit a stock b16 block
Old Jul 28, 2005 | 06:57 AM
97L-esVeeTeg's Avatar
Default Re: What does piston overbore mean? (crxowner)
stock b series = 81mm. .25 overbore = 81.25mm
so, no those slugs wont fit in stock bore b series. Take it to a machine shop
Old Jul 28, 2005 | 07:07 AM
crxowner's Avatar
thanks, how much would it cost to bore out a block?
Old Jul 28, 2005 | 07:10 AM
B18CR_EJ2's Avatar
overbore is how much larger that piston is than a regular piston. no they will not fit a stock b16, the b16 cylinders must be bored .25 over as well
Old Jul 28, 2005 | 07:39 AM
phyregod's Avatar
Default Re: What does piston overbore mean? (B18CR_EG)
Boring out a block is actually very cheap. Its all the labor in tearing down the motor and rebuilding it, if you don't do it yourself. Then you have to buy a full engine gasket set. BUT, if you do get it bored, get it milled flat, too "decked".
Old Jul 28, 2005 | 07:43 AM
crxowner's Avatar
thanks everybody
denso
Jan 19, 2009 08:44 PM
efking1985
May 23, 2008 06:57 PM
hondaapi
Apr 7, 2005 05:08 AM
teggytegteg
Nov 4, 2004 10:36 AM
