did i throw a rod? had a loud pop and all my oil emptied onto the header(LOTA SMOKE)
Old Jul 28, 2005 | 06:37 AM
CRXstress's Avatar
Default did i throw a rod? had a loud pop and all my oil emptied onto the header(LOTA SMOKE)
so after the car quits smoking i see i 3" egg shaped hole in the block directly below the exhaust manifold, when i pulled the dipstick out it had a 90 degree bend in it and i could here it rattleing things in the engine!!!!! I am the most amature mechanic in the world but i think its a connecting rod or somthing , going to tear the motor down today will post pics, also do you think i can disassemble this motor which is a d16a6 with a shop manuel from a d16y8? just curious if the procedure would be the same.
Old Jul 28, 2005 | 07:40 AM
phyregod's Avatar
Default Re: did i throw a rod? had a loud pop and all my oil emptied onto the header(LOTA SMOKE) (Mrwool9834
Yup, you puked a rod!
**edit** the shop manual will be fine, but be sure to get accurate torque specs for the various bolts, as they are sure to be different.
If you have any trouble finding a d16a6 block, let me know.
phyregod@earthlink.net
Old Jul 28, 2005 | 08:01 AM
CRXstress's Avatar
thanks but im building an ls/vtec
Old Jul 28, 2005 | 08:17 AM
CRXstress's Avatar
im working on a ls/vtec now but thanks anyway, oops typed that twice
skoodles2k6
Dec 22, 2007 05:19 PM
shorto85
15
Feb 4, 2005 10:24 PM
SuicideSlide
Oct 11, 2003 12:20 PM
