2002 EP3-T: What sort of numbers are possilbe with my setup and 440cc injectors?
Old Jul 28, 2005 | 05:38 AM
djvtoner's Avatar
Default 2002 EP3-T: What sort of numbers are possilbe with my setup and 440cc injectors?
https://honda-tech.com/zerothread?id=1321943
Thanks guys...
Old Jul 28, 2005 | 07:24 AM
Dunc's Avatar
BCICAN
Default Re: 2002 EP3-T: What sort of numbers are possilbe with my setup and 440cc injectors? (djvtoner)
I'm not sure if you are asking again or if you are just saying thanks for the help. If you are asking then:
310cc 200~220whp
370cc 220~280whp
440cc 280~330whp
550cc 330whp~380whp
660cc 380whp~425whp
720cc 425whp~475whp
880cc 475whp~525whp
980cc 525whp~600whp
Credit where it is due: You should thank Jeff Evans for those numbers.
Old Jul 28, 2005 | 07:38 AM
djvtoner's Avatar
Default Re: 2002 EP3-T: What sort of numbers are possilbe with my setup and 440cc injectors? (Dunc)
That's pretty much what i was looking for THANKS!
now with the 440cc injectors... is 280whp the safest and the 330whp the riskiest??
Is this Jeff Evans from Evans Tuning in PA? If so that's where my car is going to get tuned...
Old Jul 28, 2005 | 07:53 AM
Dunc's Avatar
BCICAN
not really....280 could be just as "risky" as 330. It is more of a general range of what to expect out of those injectors. Just datalog your cuty cycle and try to keep it around 80-85%
Old Jul 28, 2005 | 08:45 AM
b_ron007's Avatar
adj. fpr and a high pressure fuel pump is ur friend in this situation.
dsm 450's and i was @75% injector duty cycle @17psi on a Drag kit. i had a adj. fpr and a walbro high pressure fuel pump. ran it a 70psi at idle, at most saw 87psi under full boost. people wont like it, but it worked for me over a year. but again.....this was on a AEM EMS.
@8psi i made 209whp/221wtq, i never dyno'ed @17psi, but @14psi i hung with SS camarros on the free-way. so i never knew what i was making, but it sure was pretty quick for a stock block 2.3 SOHC accord
Ntraikoff
Jul 25, 2015 09:54 AM
Rickdrizzle
Jul 8, 2008 02:12 PM
11psiTurboSI
Mar 9, 2005 08:54 PM
b20turboic
Aug 27, 2003 09:16 AM
