My car went from slow, to slower... WTF?
Old Jul 28, 2005 | 05:28 AM
AngryJeremy's Avatar
Default My car went from slow, to slower... WTF?
So my best time at the track is 9.63 @ 74.6... and last night I go to the valley and run a ******* 9.88 @ 72.2 as my best.
Here's why i'm pissed:
(in addition to i/h/e and clutch)
-just installed Crower Stage 1 cams
-just had 5 angle valve job, gasket match p&p, .015" head shim
-not to mention, my buttdyno is reading a lot better pull at higher rpms but less torque before 4k rpms
Some potential explanations:
-Bad head work (but the guy is extremely credible and knows his stuff, Dan Nelson)
-Need to tune cams
-Crappy exhaust that is cut off after the resonator (getting a new one this weekend)
-High humidity... could this affect my times that much
Can anyone diagnose what the proplem could be or have any other suggestions. All help is greatly appreciated!
-Jeremy
Old Jul 28, 2005 | 06:26 AM
bubbahatch92's Avatar
Default Re: My car went from slow, to slower... WTF? (LudeSE)
The question is have you retuned the car since you instaled all the new stuff? If not then thats your problen right there.
Old Jul 28, 2005 | 06:27 AM
elrandeeto's Avatar
Default Re: My car went from slow, to slower... WTF? (bubbahatch92)
i agree tune it
Old Jul 28, 2005 | 06:32 AM
Default Re: My car went from slow, to slower... WTF? (elrandeeto)
No I have not tuned it with the new parts in, but have heard that it would not do much for me with a cam that is not very aggressive.
I am thinking along the same lines as you all and agree i should have it tuned.
So what tuning setup should I invest in?
-Hondata
-Cam Gears
-VAFC
-SAFC
-etc.
(or do I even need one?)
I don't know much about tuning and how it works but I'm assuming it could be done at the dyno for around $150?
Modified by LudeSE at 7:47 AM 7/28/2005
Modified by LudeSE at 8:35 AM 7/28/2005
Old Jul 28, 2005 | 06:56 AM
you have done modifications that allow more air to flow through your motor, and also changed your cam. Tuneing should help out alot. on all motor cars a couple more hp and a couple less pounds go a long way. As far as what system you should get to tune with well I suggest finding a local reputable tuner and find out what they perfer to work with.
Old Jul 28, 2005 | 08:33 AM
asefi944's Avatar
hondata.....
Old Jul 28, 2005 | 01:23 PM
Junglesnake's Avatar
What were your 60's this and last time at the track?
Old Jul 28, 2005 | 01:47 PM
ChewiSi's Avatar
1-tune it
2-tune it
3- tune it
Old Jul 29, 2005 | 04:20 AM
Default Re: (Junglesnake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junglesnake &raquo;</TD></TR><TR><TD CLASS="quote">What were your 60's this and last time at the track?</TD></TR></TABLE>
When I ran the 9.63, it was 2.27. When I ran the 9.88, it was 2.28. My personal best is a 2.25 which I ran a 9.68
Old Jul 29, 2005 | 04:21 AM
Default Re: (ChewiSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChewiSi &raquo;</TD></TR><TR><TD CLASS="quote">1-tune it
2-tune it
3- tune it</TD></TR></TABLE>
I have heard that Hondata does not work with a p14 ecu... What should I use to have someone dynotune it?
kimbler99
Dec 25, 2013 06:53 PM
S@nt0s
Feb 27, 2011 08:40 PM
Ronin Panda
Oct 13, 2003 03:19 PM
ITR632
Jan 16, 2003 11:52 AM
