white smoke from oil filter area. just installed oil filter relocation kit
Old Jul 28, 2005 | 03:54 AM
Jaesung's Avatar
Default white smoke from oil filter area. just installed oil filter relocation kit
it's been going on for about a week, i've tightened all the fittings and clamps, yet i drove it for a lil bit and opened up the hood. there's still some white smoke coming from under the intake manifold.
I narrowed it down to where the oil is coming from, most likely where the oil goes to the filter(stock location).
If I didn't tightened the metal oil filter adaptor fitting to the block, which I highly doubt it..
what could it be? my engine light hasn't turned on, motor runs fine but am i burning off exess oil to the atmosphere, I just don't know where to look.
if you guys can help me out, those who installed the kit by Greddy.
I probably don't even need that and just put it back to stock....
Old Jul 28, 2005 | 04:06 AM
Deemeetree's Avatar
Electrician
If you're sure it's coming from under the intake manifold, it might be from the oil filter housing. Did you tighten it down properly? Is there any o-ring on the backside of it that got pinched or is missing? Oil might be dripping down to your exhaust pipe and burning off.
Old Jul 28, 2005 | 07:44 PM
Jaesung's Avatar
Default Re: (Deemeetree)
yesterday I went under the car while the car was on the jack and the oil filter fitting block area was free from oil.
I think once the car starts to accel(throttle cable pushed in) it starts to burn oil from there.
I'll have another look. I know I haven no pictures and sorry about that.
No idea, but someone mentioned trying teflon tape?
Old Jul 28, 2005 | 07:58 PM
RareSI's Avatar
Default Re: (Jaesung)
Do NOT use Teflon tape. If that stuff gets into the oil flow, bad.
Old Jul 29, 2005 | 07:08 PM
Jaesung's Avatar
everything is as tight as it can be.
i tripple checked it.
one more try. i will try tomorrow again to see if things are tight.
it's very weird that this is happening right after I installed this relocation kit.
could it be that I blew my headgasket? can smoke come from the oil filter housing area bc i have a blown headgasket?
i hope not... er...
holmesnmanny
Dec 10, 2009 03:14 AM
bigsnorlax
Nov 6, 2009 06:43 AM
LOL@hondas
Jan 12, 2009 12:18 PM
1sikhatch
Aug 3, 2008 02:42 PM
NINJA
Aug 2, 2003 11:56 AM
