RSXer needs final drive expertise from his DC2 brethren
Old Feb 19, 2002 | 09:52 AM
ArcticFreeze's Avatar
New User
Default RSXer needs final drive expertise from his DC2 brethren
Okay, I know how well versed all of you are on final drives, so I'm gonna throw this one out.
I want to replace the 4.38 final drive in my RSX-S with a shorter one. The new Si, DC5-R and CTR all use a FD in the 4.7 range. I know the ITR and CTR FDs would probably bolt in, but I'd like to use the Si FD for cost reasons.
Considering the Civic and RSX both use the K20 motor, would the final drive in the Si 5sp bolt into the 6sp tranny in the RSX?
Thanks much!
Old Feb 19, 2002 | 10:05 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: RSXer needs final drive expertise from his DC2 brethren (ArcticFreeze)
Thanks much!
Maybe, maybe not. All B-series trannies (to my knowledge) can fit the same size diff/final drive, but I have no experience with K-series trannies.. if both (edit: tranny housings) can fit it, then yes, you can swap it over, but there might be a countershaft difference, etc as well.
[Modified by Dominic Toretto, 2:06 PM 2/19/2002]
Old Feb 19, 2002 | 10:42 AM
houston's Avatar
Default Re: RSXer needs final drive expertise from his DC2 brethren (Dominic Toretto)
its highly doubtfula 5spd FD is gonna work on a 6pd tranny.. ive seen miracles but im gonna doubt that one..
let someone else be the guinea pig
Old Feb 19, 2002 | 10:59 AM
b00st-0wnz's Avatar
Default Re: RSXer needs final drive expertise from his DC2 brethren (houston)
There's no reason for it not to just because there's an extra gear on the countershaft/mainshaft. But you will need to swap more than just the FD.
efyou
17
Apr 13, 2006 10:37 AM
LSVtecEK1
Oct 25, 2005 09:33 PM
K20EG
Oct 5, 2003 01:45 PM
kikiboi
Sep 12, 2003 03:54 AM
ArcticFreeze
Feb 19, 2002 10:40 AM
