crap; which AC and ALT belts fit a jdm itr?
i need to change my alt and ac belts on my 99 jdm r. i went to the autoparts store and ordered the belts for a 00 us itr and they were way too big. after trying 3 other smaller sizes i had exhausted the store's stock and am just SOL. anyone out there have a brand and part # they know works with the jdm Rs?
thanks
Modified by confidence at 10:12 PM 10/27/2007
thanks
No theyre different...the alternator belt is definitley different as i had this problem when i went to change mine...in the end up i ended up getting a UK ITR alternator (cheap) and swapping the whole thing.
I still have th Bando belts that were on mine so i'll see if theres part numbers on them and maybe you can get them through a Bando dealer in the US (if they have outlets there)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer »</TD></TR><TR><TD CLASS="quote">I still have th[e] Bando belts that were on mine so i'll see if theres part numbers on them and maybe you can get them through a Bando dealer in the US (if they have outlets there)</TD></TR></TABLE>
FYI -- the BANDO belts were sent with the AEM pulley sets, and were smaller than stock.
just measure the distance around the pully's with string, if it 32-1/2inches and 3 rib the part # (most aftermarket company's) would be 325k3 or if its 34inches and 4 rib its 340k4 -get it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">
FYI -- the BANDO belts were sent with the AEM pulley sets, and were smaller than stock.</TD></TR></TABLE>
My car came with bando belts on everything, i'm just assuming theyre OE replacement belts that were fitted in japan by the last owner.
Bbasso...numerous JDM ITR owners here have had the same problem, but they managed to get belts that fitted, it was the pulleys that were different, the brackets are probably the same
well i ended up getting a belt for an LS integra. i was told by the chick at the parts counter its the same as the GSR belt. the ac belt i had to use came from a gsr as well.
