Best all motor idea for a 92 integra ls !!! GIVE ME YOUR SUGESTIONS!!!
Old Jul 27, 2005 | 08:11 PM
integra_kid05's Avatar
Default Best all motor idea for a 92 integra ls !!! GIVE ME YOUR SUGESTIONS!!!
I have this car 92 integra ls and Im going to spend about 5000 $ for the motor...im not sure the best way to go all motor is but i need to know! i want to be in high 12's all motor so ill do what i have to do to get there....just tell me how !
Thanks
Old Jul 27, 2005 | 10:16 PM
egerdahl's Avatar
Default Re: Best all motor idea for a 92 integra ls !!! GIVE ME YOUR SUGESTIONS!!! (integra_kid05)
Honda Tuning magazine did a nice all motor build up on a 3rd gen. integra with a $10,000. budget and were able to run 13's with it. That $10,000. included buying the car so I think you would be able to make your engine bomb proof with your $5,000. I would look into rods and pistons and for sure get some head work done!! That way if you build up your bottom end now and are able to run 12's and 13's on all engine setup you can always throw a turbo on that bad boy and really tear up the track
Old Jul 28, 2005 | 11:46 AM
Default Re: Best all motor idea for a 92 integra ls !!! GIVE ME YOUR SUGESTIONS!!! (egerdahl)
I actually figured out what im going to do and its going to be sick
stuff man. Im gettin a b20 block and im gettin it sleeved and then im
getting a b16 head and im going to build it till i can tbuild itno
more....then after those are all said and done ima put it together and put it
in my car...And by sleeving the b20 block i will be able to turbo it
later and i could run like close to 20 lbs of boost because the motor wil
hold it...But if you can find a b20 block then let me know or a b16
head.....i would love to get started when i can...thanks
Old Jul 28, 2005 | 12:07 PM
Miz101's Avatar
Hmm I would suggest you do a lot of reading before you go LS/VTEC route. You can always just get a B18B sleeve it and turbo it later.
Old Jul 28, 2005 | 12:17 PM
7k rdlne's Avatar
Default Re: Best all motor idea for a 92 integra ls !!! GIVE ME YOUR SUGESTIONS!!! (Miz101)
sounds like you have a lot of research to do , youll have to decide if you want to do an all motor build or turbo build. if you plan on boosting youll have to build a low compression motor, if you plan to stay motor your gonna want high compression. if your interested in boosting check out the fi forums, lots of good info there. good luck
Old Jul 28, 2005 | 12:18 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miz101 &raquo;</TD></TR><TR><TD CLASS="quote">Hmm I would suggest you do a lot of reading before you go LS/VTEC route. You can always just get a B18B sleeve it and turbo it later.</TD></TR></TABLE>
i think lsvtec would probably be a good way to go. to get any real power out of that motor, he's going to have to take it apart and bump the compression anyway. with 5k you should be able to build it pretty strong.
Old Jul 28, 2005 | 12:30 PM
Miz101's Avatar
Default Re: Best all motor idea for a 92 integra ls !!! GIVE ME YOUR SUGESTIONS!!! (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">i think lsvtec would probably be a good way to go. to get any real power out of that motor, he's going to have to take it apart and bump the compression anyway. with 5k you should be able to build it pretty strong.</TD></TR></TABLE>
Well he doesn't have to bump the compression. The B18B comes 9.2:1 stock so it's ok for boost and can hold what 6-7 pounds of boost safely? I think some people have taken them to 14psi stock internals. Either way he doesn't really know what route he wants to go so it might not be a good thing to do lsvtec + boost. Might end up having a bomb instead of an engine.
Old Jul 28, 2005 | 12:34 PM
LSvtec03's Avatar
i guess i just got confused because first he said he wanted to go all-motor, then he said he wanted to go turbo, so it all depends on him. ya can't have both!
the compression is fine for boost, although i would personally go with forged rods and pistons, but if you decide on all-motor, you will want to bump the compression.
Old Jul 28, 2005 | 12:46 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
read read read read read read
research research research
I researched for almost a year before I built my lsvtec in my DA....MAKE SURE YOU GET A YS1 or short gear trans!!!
The only regret I have is not going B20 bottom end
Chris
Old Jul 28, 2005 | 02:12 PM
kNOwLedGeDA9
Guest
Posts: n/a
A good way to make decent power all motor is to use the B20B/Z block but ditch the 89mm crankshaft. The B20 block is the same as your B18A1 block but it has 84mm sleeves instead of 81mm. By putting in a B18C crankshaft and rods in the B20 block, you DE-STROKE the engine and lower the piston speeds. This way you get the best of both worlds. You have the B18C's ideal stroke that is safe to revv high to utilize high lift camshafts, but with added displacement of 84mm bore. It yields about 1830cc like an LS/VTEC but the added displacement over the 1797cc B18C comes from bore size and not stroke. All in all, you have over 1800cc's and can safely revv over 9,000 (not stock) without worry.
Old Jul 28, 2005 | 02:19 PM
Default Re: (kNOwLedGeDA9)
yeah, Well I seen a guy put a b20 block with a b16 head on it and hes runnin 13.01 all motor in a civic hatch. So he told me that if i sleeved it (which most people dont do tothe b20 but...) and then boosted it then it would be hella power for the weight of my car....i just want something fast as **** so right now the b20 block and b16 have been my best bet...because his is nasty and mine boosted would be ever more power ....
Old Jul 28, 2005 | 02:20 PM
Default Re: (integra_kid05)
I was thinkin of using the 5 g's for the motor part and later adding a turbo just so ya know
mattmw88
Aug 25, 2004 08:54 PM
phatgt4evr
Aug 18, 2004 05:50 PM
91_hatch_si
Jan 12, 2003 09:37 PM
