Not Honda, but help needed please....
Old Feb 19, 2002 | 09:11 AM
Butch's Avatar
Default Not Honda, but help needed please....
I put a remote starter in a 02 Durango and cannot find a strong enough signal for the tach wire. I have tried the coil, wrapping the tach wire around the #1 plug wire, etc but still no luck. The truck starts, runs for 3 seconds, and shuts back down. It does not have the immobilizer so that's not it. The tech guy at Accelle said I'm not getting a strong enough signal on the tach wire but had no ideas where to get a stronger one. I have also swapped the brain out to see if it was maybe bad. Can anybody help me or direct me to a website that can? Thanks
Old Feb 19, 2002 | 03:11 PM
nsxxtreme's Avatar
Default Re: Not Honda, but help needed please.... (Butch)
I believe clifford sells a module that will do this for you.
Old Feb 20, 2002 | 08:01 PM
t's Avatar
t
The Black/grey wire at the coil works. Did you tap it into the right wire?
Old Feb 21, 2002 | 09:22 AM
Butch's Avatar
Default Re: Not Honda, but help needed please.... (t)
The coil had 3 wires coming from it. They were all 3 together. solid black on each side with a blk/gry in the middle. I tapped into it but it didn't change anything.
4gen4drcivic
10
Feb 2, 2009 09:23 AM
slimjimdanny
Jan 31, 2007 07:35 PM
93AcuraIntegraGSR
Jan 21, 2007 03:02 PM
1sikhatch
11
Mar 14, 2006 09:19 PM
preluder
Dec 22, 2002 09:51 PM
