TPS is killing me, hel plz
I got a 99 Ex coupe auto , in the last 8 months I have replaced about 3 TPS's. I put them all on correctly, checked them with a mutlimeter, after 2-3 months I get code 7 ... any suggestions?
does it have a high idle, if so u may want a new throttle body cuz i had that problem with the spring which can be replaced but i decided to buy a new tb and it worked
I had the little pins inside the plug get corroded and do that. The springy part corroded completely away, causing an intermittent connection. I grabbed some pins from my cruise control plug and put them in the TPS plug, no problems since.
SoHov
Oct 28, 2005 10:16 AM
