over bore on b18c1
what up all! i'm thinking of boring out my block with .25 o.s. jdm itr pistons. i just want to know what my displacement will be? and also, my friends tell me i can go to NAPA to get my machine work done. is that a good idea? and how much does something like this cost? would i need to do the same thing to my combustion chamber also?
when boring over to .25 is to just to clean up the sctraches on the walls and what not.. it will not affect displacement enough to make a difference ..
this is IMO...
so no to the combustion chamber question and about NAPA you would have to see if anyone has used them before....
this is IMO...
Youll go from 1797cc's to 1808cc's, and a compression ratio of 10.0:1 to 10.6:1
Got this from c-speedracing.com
When it comes to honda's, especially na ones, every little bit helps, i'd say do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr19 »</TD></TR><TR><TD CLASS="quote">Youll go from 1797cc's to 1808cc's, and a compression ratio of 10.0:1 to 10.6:1
i'm just wonderin why my comp would go up. thanks!
You are going with a bigger dome on the piston than your stock usdm p72 ones.
Less room in the combustion chamber at TDC = more compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr19 »</TD></TR><TR><TD CLASS="quote">You are going with a bigger dome on the piston than your stock usdm p72 ones.
Less room in the combustion chamber at TDC = more compression.</TD></TR></TABLE>yeah tru. that makes sense. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninor »</TD></TR><TR><TD CLASS="quote">comp ratio is more like 11.3:1</TD></TR></TABLE>
Neg.
Check it yourself...
http://www.c-speedracing.com/h...c.php
Neg.
Neg.
http://www.c-speedracing.com/h...c.php</TD></TR></TABLE>
Quit being a ****. GO back, correct the cylinder bore size, MAKE SURE to select stock head gasket thickness and a B18C1 cylinder head along with JDM ITR pistons and you will get:
11.415091306947745
Thank you, drive through.
Neg.
11.415091306947745
itrsleeper
Dec 6, 2005 10:33 PM
whitelightning
24
Aug 3, 2005 08:33 PM
Finger Lickin' good
27
Jul 30, 2005 03:08 PM
lemongreenhatch
Jun 15, 2004 11:51 PM
