Skunk2 Stage 2 Intake Cam Busted!! What Now? Warranty?
Old Jul 27, 2005 | 05:39 PM
SiBuddy00's Avatar
Default Skunk2 Stage 2 Intake Cam Busted!! What Now? Warranty?
Skunk2 Stage 2 intake cam busted the other day. I was reading on Skunk2's site about warranty ****, and it reads as if they don't warranty anything. My friends coil on his coilover broke from skunk. He got his **** replaced, and another one of my friends stage 2 skunk2 cam busted, and he got it warrantied. What should be said to skunk2? I'm not the greatest..... talker with things like this. Any tips or suggestions? I don't have any money to buy another set, need to get these warrantied, or are there any reps on here that can help me out?
Old Jul 27, 2005 | 05:43 PM
DonF's Avatar
Default Re: Skunk2 Stage 2 Intake Cam Busted!! What Now? Warranty? (SiBuddy00)
What springs and retainers did you have? Where did you have the cams installed at degree wise? What was te valve to valve Cl. what was the valve to piston cl.
Old Jul 27, 2005 | 06:31 PM
Suck my DX's Avatar
Default Re: Skunk2 Stage 2 Intake Cam Busted!! What Now? Warranty? (DonF)
why dont u just call them and tell them the situation and see what they say....it never hurts to ask....if ur homies got their **** replaced why wouldnt u? more than likely it was installation error...thats the #1 reason why cams break...
Old Jul 27, 2005 | 07:15 PM
civicgsr19's Avatar
Default Re: Skunk2 Stage 2 Intake Cam Busted!! What Now? Warranty? (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">why dont u just call them and tell them the situation and see what they say....it never hurts to ask....if ur homies got their **** replaced why wouldnt u? more than likely it was installation error...thats the #1 reason why cams break...</TD></TR></TABLE>
What is the biggest reason this happens? is it overtightening the cam gear bolt?
Old Jul 27, 2005 | 07:28 PM
jdmsiR20's Avatar
Default Re: Skunk2 Stage 2 Intake Cam Busted!! What Now? Warranty? (civicgsr19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr19 &raquo;</TD></TR><TR><TD CLASS="quote">
What is the biggest reason this happens? is it overtightening the cam gear bolt?</TD></TR></TABLE>
where exactly did the cam break at?
the biggest reason i would think is tightening the cam caps in the wrong sequence....
Old Jul 27, 2005 | 09:14 PM
Suck my DX's Avatar
Default Re: Skunk2 Stage 2 Intake Cam Busted!! What Now? Warranty? (jdmsiR20)
yes if the cam is not seated properly ,it can cause it to break...
Old Jul 27, 2005 | 09:18 PM
RMF
Guest
Posts: n/a
And what else happens is ,the intake valve hits the exhaust valve and bends them over and the piston comes up and smashes em over .And when the cam comes back around .It can't push the valve down so it breaks the cam.Did the piston hit the valves?
Old Jul 27, 2005 | 09:46 PM
GOLDBERG's Avatar
another reason for cam breakage is using an impact on the cam gear bolts..youd be suprised what some people do
Old Jul 27, 2005 | 10:34 PM
jt-sport's Avatar
dave.... costumer need help here..
Old Jul 28, 2005 | 02:38 AM
jdm123's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">What springs and retainers did you have? Where did you have the cams installed at degree wise? What was te valve to valve Cl. what was the valve to piston cl.</TD></TR></TABLE>
skunk two retainers and amd valve springs, which only had about 4k miles on them when he was reassemblying the head,
Old Jul 30, 2005 | 07:18 PM
RMF
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote"> Where did you have the cams installed at degree wise? </TD></TR></TABLE>
Why? Wouldn't it be better to do it when its cooler? Because its 120 degrees where I live.LOL
Old Jul 31, 2005 | 05:26 PM
SiBuddy00's Avatar
Default Re: Skunk2 Stage 2 Intake Cam Busted!! What Now? Warranty? (RMF)
no advancing, no retarding, stock timing
Old Jul 31, 2005 | 08:38 PM
ShaunRR's Avatar
HT White Ops
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote">Why? Wouldn't it be better to do it when its cooler? Because its 120 degrees where I live.LOL </TD></TR></TABLE>
Looks like cams aren't the only thing that can be retarded
Old Jul 31, 2005 | 09:41 PM
snowseeker's Avatar
Default Re: Skunk2 Stage 2 Intake Cam Busted!! What Now? Warranty? (rochesterricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer &raquo;</TD></TR><TR><TD CLASS="quote">
Looks like cams aren't the only thing that can be retarded </TD></TR></TABLE>
I just had to laugh.
jrdelviento
Jan 31, 2007 05:29 AM
tomlinson619
Apr 1, 2006 12:05 AM
Simple SOHC
30
Aug 20, 2004 12:09 PM
Full-Race Henry
Mar 22, 2003 05:36 PM
