obd0 Injectors?
I have a intake mani from a 97 ex with the IPT fuel rail and obd1 injectors, i'm guessing. Is there a visual way to tell between obd0 and obd1. Also, will a obd0 fuel rail and injectors work with this intake for the mpfi swap on a dx?
Thanks in advance for any help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89cmutr »</TD></TR><TR><TD CLASS="quote">I have a intake mani from a 97 ex with the IPT fuel rail and obd1 injectors, i'm guessing. Is there a visual way to tell between obd0 and obd1. Also, will a obd0 fuel rail and injectors work with this intake for the mpfi swap on a dx?
Thanks in advance for any help!</TD></TR></TABLE>
If you have a manifold from a 1997 EX then you have a D16Y8 manifold and that comes with OBD-2 injectors. The only fuel rail that works on that manifold is the Y8 and the Y7 if I am not mistaken. It does not matter the OBD level of the injectors that are going into the fuel rail as long as the wiring to the ecu is correct for said injectors. Yes you can use this manifold for an MPFI swap, it just will change a few steps (minor).
In no particular order....
Relocate and extend IAT wiring
Reroute PCV system
Trim Brake Booster Vaccum Line
Extend Fuel Return Line to FPR
Extend MAP wiring (If using TB w/MAP)
Reroute PCV system
91legend
12
Nov 27, 2012 01:34 PM
thedudefromjerz
Feb 21, 2008 02:52 PM
thrty8street
10
Nov 11, 2004 02:18 PM
