Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Wheels - Stock vs. Aftermarket.
Old Feb 19, 2002 | 08:24 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Wheels - Stock vs. Aftermarket.
I need to opinion from a competition point of view.
Statements:
- Aftermarket alloys are lighter, than stock steel. Lighter wheels offer better performance, etc, etc.
- Stock steel wheels are heavy, so therefore slow you down, etc., etc.
- Aftermarket wheels are generally WIDER than stock steel. Let's say I have a 89 Integra. Stock steel 14X5.5. Aftermarket alloy wheel 14X6. Tires would be exactly the same size 195/60/14 for both.
Question:
If the above statements are true. Then wouldn't the wider (lighter) aftermarket alloy wheel, actually be heavier than the stock steel wheel, because it's wider? Therefore decrease performance?
Again, this is a general statement in theory, rather than comparing actual wheels.
Please comment, educate, and advise.
Mods - if this question is better suited for another section, please move.
Thanks
Old Feb 19, 2002 | 08:47 AM
.RJ's Avatar
.RJ
Default Re: Wheels - Stock vs. Aftermarket. (GoLowDrew)
for competition you want the smallest (diameter), widest wheel you can fit on your car.... unless you're restricted to use a certain rim size (such as stock).
The material of the wheel and how the wheel is made dictates its final weight much more than its width... diamater also plays a role (larger diameter wheels are generally heavier, of the same type). You can get cast aluminum (heavy), forged alumimum (light but still strong), spun/rolled alumium (light but weak), steel (really heavy), magnesium (light and strong), forged magnesium ($$$$$), and so on....
-Ryan
Statements:
Question:
Thanks
Old Feb 19, 2002 | 10:39 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Re: Wheels - Stock vs. Aftermarket. (Type-RJ)
To summarize my question, the stock steel wheels are generally more narrow than aftermarket alloy. Given that the alloys are lighter, wouldn't the extra width = weight negate the effect of a lighter wheel?
Old Feb 19, 2002 | 10:41 AM
Willard's Avatar
Material differences = less weight for aftermarket stuff.
O.E. stuff has to put up with a lot more abuse (hight factor of saftey) than aftermarket stuff.
Will
Old Feb 19, 2002 | 02:10 PM
.RJ's Avatar
.RJ
Not necessarily... different materials weigh differing amounts. So you can have a larger/wider wheel that weighs less than stock - but then you have to worry about moment of inertia and such...
-Ryan
Old Feb 19, 2002 | 06:27 PM
Willard's Avatar
Manufacturing differences can play a part (cast verses forged).
Will
Old Feb 20, 2002 | 04:35 AM
Cold Chunker's Avatar
Default Re: Wheels - Stock vs. Aftermarket. (Willard)
As Will said. For example, roughly, my stocks are 15x6=16lbs - SSR Comps are 15x7.5=10lbs. Bigger wheel and less weight = good track wheel.
Think about it - a corrugated box will weigh a lot less than a wood box, but may be structurally stronger.
crxb18ls
Other Make Vehicles
Sep 25, 2008 06:18 PM
.::Lee::.
Dec 15, 2004 09:36 PM
Another Drew
Oct 7, 2003 06:41 PM
typeRdriver
Oct 6, 2002 11:04 PM
