Obd2 head in obd1 car?
Old Jul 27, 2005 | 02:42 PM
3gsi's Avatar
Default Obd2 head in obd1 car?
I've searched for the answer but cannot find the it. I have a 95 LS and I'm going to put a new motor in it. I'm about to buy a GSR block with an ITR crank and eagle rods, and I'm going all-motor. I'm going to put ITR pistons in it also. I need help deciding which head to use, b16 or GSR. Can I use the b16 head off a 00si? I'm not sure if the sensors will work since its obd2 and my car and the block is obd1. Or would I be better off using a GSR obd1 head? Thanks for the help
Old Jul 27, 2005 | 02:46 PM
BlackDAy's Avatar
Default Re: Obd2 head in obd1 car? (3gsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3gsi &raquo;</TD></TR><TR><TD CLASS="quote">I've searched for the answer but cannot find the it. I have a 95 LS and I'm going to put a new motor in it. I'm about to buy a GSR block with an ITR crank and eagle rods, and I'm going all-motor. I'm going to put ITR pistons in it also. I need help deciding which head to use, b16 or GSR. Can I use the b16 head off a 00si? I'm not sure if the sensors will work since its obd2 and my car and the block is obd1. Or would I be better off using a GSR obd1 head? Thanks for the help
i would use a b16 head. the sensors should work. the only thing u have to do is use your ls distributor and injectors. I would just convert everything to obd 1 though. that's just me.
Old Jul 27, 2005 | 08:43 PM
3gsi's Avatar
Default Re: Obd2 head in obd1 car? (BlackDAy)
thanks man thats the first answer anybody has given me and I posted on 2 different boards.
JDMBoostedDA
Jul 24, 2007 11:50 AM
Project_EK
May 25, 2006 06:48 PM
3gsi
Aug 6, 2005 05:09 PM
toda_eg6
Mar 6, 2005 07:53 AM
Mikizzle
Jun 9, 2004 06:13 PM
