sneaky way to fill transmission
Old Jul 27, 2005 | 12:52 PM
90crxterror's Avatar
Default sneaky way to fill transmission
ok, i have a stock 90 crx Si. D16A6 and it doesn't seem like theres a real sneaky way to fill it up with fluid.. it seems like the only two things on top of the tranny are the drain hose, and this other black thing that doesn't come out or move(that must be the VSS...) but mine looks different than every other pic i've seen on here....
so can i fill the whole thing using the drain hose, and just use the hose as a fill hose?? or what else could i do..
also: what would be the best way to flush it out, and what should i use to do that?
Old Jul 27, 2005 | 01:47 PM
Chiovnidca's Avatar
Default Re: sneaky way to fill transmission (90crxterror)
What's wrong with putting it in through the filler hole?
Old Jul 27, 2005 | 02:15 PM
eg6T's Avatar
Default Re: sneaky way to fill transmission (Chiovnidca)
im not sure on that engine but cant you put it through where the speed sensor is?
Ef4doorwagon
Sep 13, 2014 09:09 AM
Doh!
May 22, 2006 02:47 PM
90crxterror
16
Jul 28, 2005 10:12 AM
japspecjohn
10
Sep 19, 2004 01:15 PM
Floyd
May 9, 2002 10:58 AM
