CAN I PUT AND LS CRAKSHAFT ON A B18C1 BLOCK?
I MESS UP MY GSR CRANKSHAFT AND I HAVE SOME LS CRANKSHAFT AND LS RODS CAN I PUT THIS ON MY GSR BLOCK OR IF ANY ONE HAS A STCK GSR CRANKSHAFT FOR SALE OR WHERE CAN I GET ONE THANKS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STRAKTUS »</TD></TR><TR><TD CLASS="quote">I MESS UP MY GSR CRANKSHAFT AND I HAVE SOME LS CRANKSHAFT AND LS RODS CAN I PUT THIS ON MY GSR BLOCK OR IF ANY ONE HAS A STCK GSR CRANKSHAFT FOR SALE OR WHERE CAN I GET ONE THANKS</TD></TR></TABLE>
Ls crank in the GSR block would give you some good potential. Just make sure you get the oil squirters out of the way.
P.S. caps lock, turn it off.
I'm currently trying to do that setup in my b18c1 too. And the on 2nd and 4th cylinder the piston, and the crank counter weights sandwiches the oil squirts. Can anyone tell me how to bend this correctly, or how to prevent it from getting slap around? Expert advice???
AHHHH!!! what are you peeps thinking? just because you blance your rotating mass doesnt mean you can buzz the motor to the moon. you have to consier rod stroke, AND the fact that the stock rod bolts suck *** on ls motors (even if you replace them with arp's it doesnt make it that much stronger). ok... rod stroke broken down
b18b
137mm rod
89mm stroke
8mm rod bolt
137/89 =1.5393 r/s ratio
stock rev limit = 6900rpm
b18c
138mm rod
87.5mm stroke
9mm rod bolt
138/87.5 = 1.5771 r/s ratio
stock rev limit = 8200 rpm
b16
134.4mm rod
77.4mm crank
8mm rod bolt? (not sure)
1.7364 r/s ratio
stock rev = 8200 rpm
now... your probably wondering, if the b16 has such a badass r/s why cant you rev forever? well, you can (hehe, almost), but the problem is, the stock cylinder head cannot flow enough air.
anyways, i just thought i'd let you know some of that info. but if you have some theory on why the ls crank is so great (other that that measly few ft lbs) please explain it to me.
b18b
137mm rod
89mm stroke
8mm rod bolt
b18c
138mm rod
87.5mm stroke
9mm rod bolt
b16
134.4mm rod
77.4mm crank
1.7364 r/s ratio
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STRAKTUS »</TD></TR><TR><TD CLASS="quote">CAN I PUT THIS ON MY GSR BLOCK</TD></TR></TABLE>
Yes. Lift up the crankshaft, and strategically place it on top of the the selected block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blu3g »</TD></TR><TR><TD CLASS="quote">I'm currently trying to do that setup in my b18c1 too. And the on 2nd and 4th cylinder the piston, and the crank counter weights sandwiches the oil squirts. Can anyone tell me how to bend this correctly, or how to prevent it from getting slap around? Expert advice???</TD></TR></TABLE>
bend them however you can, just dont break them, it'll work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">
Yes. Lift up the crankshaft, and strategically place it on top of the the selected block.</TD></TR></TABLE>
hell, i would just go with a V8 crank then, mad torque yo..
Lol nice
Lol nice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcb16 »</TD></TR><TR><TD CLASS="quote">AHHHH!!! what are you peeps thinking? just because you blance your rotating mass doesnt mean you can buzz the motor to the moon. you have to consier rod stroke, AND the fact that the stock rod bolts suck *** on ls motors (even if you replace them with arp's it doesnt make it that much stronger). ok... rod stroke broken down
b18b
137mm rod
89mm stroke
8mm rod bolt
b18c
138mm rod
87.5mm stroke
9mm rod bolt
b16
134.4mm rod
77.4mm crank
1.7364 r/s ratio
i rev my ITR with an Ls crank to 8700 when i race. and thats just because i want it to last. it makes power farther than that. we pull to 9+ on the dyno and its fine. bearings are great.leakdown #s are great, cylinder walls looked good as of 4000miles on the motor. if you build it correctly, you can get the benefit of the "measly few ft lbs" without the cons you are referring to.
as for the oil squirters, just make sure you have enough clearance between them and the crank. bend them enough out of the cranks way. and then either bend them again, or cut the skirt of the piston to clear the piston.
b18b
137mm rod
89mm stroke
8mm rod bolt
b18c
138mm rod
87.5mm stroke
9mm rod bolt
b16
134.4mm rod
77.4mm crank
1.7364 r/s ratio
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPRacing »</TD></TR><TR><TD CLASS="quote">
as for the oil squirters, just make sure you have enough clearance between them and the crank. bend them enough out of the cranks way. and then either bend them again, or cut the skirt of the piston to clear the piston.</TD></TR></TABLE>
i never said you can't rev to 9k or even 10k for that matter. its a matter of reliability. my friend revved his built ls-v to 9.5 all day. how long did it last? less than 4 months. this was with crower rods.
b18b
137mm rod
89mm stroke
8mm rod bolt
b18c
138mm rod
87.5mm stroke
9mm rod bolt
b16
134.4mm rod
77.4mm crank
1.7364 r/s ratio
Are you the kind of person who reads some **** on the internet and thinks he knows it all? There are more benefits than just "a few measly lb. ft.". I'd explain it to you, but I'm lazy.
b18b
137mm rod
89mm stroke
8mm rod bolt
b18c
138mm rod
87.5mm stroke
9mm rod bolt
b16
134.4mm rod
77.4mm crank
1.7364 r/s ratio
to answer your question. yes you can. and if you have the ls crank, then do it! i've heard that the oil squirters get in the way so i would do some research on that. but i wouldnt want to put those ls pistons in, they will lower you compression ratio. I'm sure you could find a deal on some OEM pistons
to answer your question. yes you can. and if you have the ls crank, then do it! i've heard that the oil squirters get in the way so i would do some research on that. but i wouldnt want to put those ls pistons in, they will lower you compression ratio. I'm sure you could find a deal on some OEM pistons</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6i »</TD></TR><TR><TD CLASS="quote">
read and you shall learn!
i never said you can't rev to 9k or even 10k for that matter. its a matter of reliability. my friend revved his built ls-v to 9.5 all day. how long did it last? less than 4 months. this was with crower rods. </TD></TR></TABLE>
What happened to it, why did it only last 4 months, I'm curious. If you could be a little more specific...
quick question:
I had allways thought that the B18A/B block was 1mm taller than the B18C, so when you put the B18A/B crank in rods in the B18C the piston stuck out 1mm more?
Am i wrong? is the B18B and the B18C block identical (except for oil squirters/girdle/oil cooler/etc.)? so in theory can I put GSR crank and rods in a LS and have it work the same?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noboostedEGo »</TD></TR><TR><TD CLASS="quote">
what happens to all of those who overrev b18a/b?
rod through the block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE »</TD></TR><TR><TD CLASS="quote">quick question:
Am i wrong? is the B18B and the B18C block identical (except for oil squirters/girdle/oil cooler/etc.)? so in theory can I put GSR crank and rods in a LS and have it work the same?</TD></TR></TABLE>
im not sure if the deck heights are the same, but either way it will work. here is why:
gsr stroke = 87.5mm
gsr rod = 138mm
(87.5+138)
ls stroke = 89mm
ls rod = 137mm
(89+137=226)
now the only other factor i can think of that will affect you piston to deck clearance is piston height (that is measured from the center of the wrist pin to the top of the piston [no, the top of the piston is not the top of the dome]) Now dont quote me, but i think it would be safe to assume that they would have identical piston heights, but someone please correct me if i am wrong.
</TD></TR></TABLE>what happens to all of those who overrev b18a/b?
gsr stroke = 87.5mm
gsr rod = 138mm
(87.5+138)
ls stroke = 89mm
ls rod = 137mm
(89+137=226)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcb16 »</TD></TR><TR><TD CLASS="quote">hahahaha... so you want to call me out and then dont back it up?
wow.... your special
Thank you. Now go read some more and spread your vast resource of Honda knowledge.
</TD></TR></TABLE>Thank you. Now go read some more and spread your vast resource of Honda knowledge.
look man, this sight is about spreading knowledge, not bashing. now if your going to call me out and say that i'm misinformed, please back yourself up. if you arent going to do that, than please dont say anything at all. it's people like you that have ruined what HT used to be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcb16 »</TD></TR><TR><TD CLASS="quote"> Now dont quote me, but i think it would be safe to assume that they would have identical piston heights, but someone please correct me if i am wrong.</TD></TR></TABLE>
No they don't. Specific information is readily available here on Honda-Tech.
The rod/stroke ratio isn't really a good indicator of how high a motor can rev. A smaller rod/stroke ratio means more lateral stress on the cylinder walls which causes weaker engines to lose stability and do nasty, evil things. Lack of balance also causes instability which leads to similar nasty, evil things. By correctly balancing/blueprinting the rotating assembly and replacing the stock sleeves with stronger, more stable ones, you'll have problems in the head well before the bottom end has reached it's limits.
