Quick Question about ECU codes...
Old Jul 27, 2005 | 10:17 AM
EF7's Avatar
EF7
Default Quick Question about ECU codes...
Where is the red flashing light located on a EG?
I've always worked on EFs and all I needed to do was to lift up the carpet and there it was... help!
and yes, I searched and I looked at the ECU, even removed it but no red flashing light...
Old Jul 27, 2005 | 10:24 AM
JDM-EJ1's Avatar
Default Re: Quick Question about ECU codes... (EF7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF7 &raquo;</TD></TR><TR><TD CLASS="quote">Where is the red flashing light located on a EG?
and yes, I searched and I looked at the ECU, even removed it but no red flashing light...</TD></TR></TABLE>
What light are you talking about?
Old Jul 27, 2005 | 10:29 AM
EF7's Avatar
EF7
Default Re: Quick Question about ECU codes... (JDM-EJ1)
On the 88-91 Civics there is a flashing red light on the ECU and if you have a problem it will flash a number of times = ECU code / but I don't know if the EGs use the same system. All I need to know is how do you check the ECU codes on a EG. Thanks.
Old Jul 27, 2005 | 10:30 AM
Luserkid's Avatar
OBD0 cars have there CEL on the ecu and not in the dash.
92 + have it in the dash and you need to jump it to read the codes. Look here:
https://honda-tech.com/zerothread?id=1171263
Old Jul 27, 2005 | 10:46 AM
EF7's Avatar
EF7
Default Re: Quick Question about ECU codes... (Luserkid)
Thanks for the help!
Problem solved.
AMseven
Jul 3, 2009 09:30 PM
jfields06
Dec 27, 2008 06:42 AM
cuseikan
Aug 18, 2008 01:26 PM
innes887
Apr 26, 2007 01:04 PM
jason_alt
Mar 3, 2004 07:08 PM
