If I have 205-50-15's up front, and 195-55's in the back, will it look wierd?
Old Feb 19, 2002 | 07:26 AM
Chip398193's Avatar
New User
Default If I have 205-50-15's up front, and 195-55's in the back, will it look wierd?
On my 95 ls with 2000 gsr wheels. for some reason, the guy i got the gsr wheels from used 205-50's. the 2 back ones are very bald, and i need new ones asap. My friend has 2 195-55-15's he'll give me . will it be ok? and will it be notcisable? remember, they are both going on the back...
Old Feb 19, 2002 | 07:36 AM
madchiller's Avatar
Premium Member
25 Year Member
Default Re: If I have 205-50-15's up front, and 195-55's in the back, will it look wierd? (Chip398193)
are you insane, go buy tires that match!
Old Feb 19, 2002 | 07:41 AM
b18bvtec4drteg's Avatar
Well if its free go for it. You got nothing to lose.
I would put the 195-55-15's he'll give you on the front and the thicker ones in the back. Its a very minimal difference if you're not ****. But I would not put those on the back if I were you.
Old Feb 19, 2002 | 07:42 AM
Rainmaker's Avatar
It'll look kind of autocross-y. It will definitely be noticeable to the eye. Also, assuming the rubber compounds are similar, you will add a little oversteer. So, I guess it could be beneficial for handling purposes.
Old Feb 19, 2002 | 07:47 AM
vwong's Avatar
Default Re: If I have 205-50-15's up front, and 195-55's in the back, will it look wierd? (Rainmaker)
It's perfectly fine. If I stick with the 15" for my Integra, that's what I'm gonna do, put 205/50R15 up front and 195/55R15 on the rear. In fact, my Prelude is running 225/45R16 up front and 205/50R16 on the rear. Great combo if you do auto-x. The only drawback for me now is that I can't rotate the tires.
Old Feb 19, 2002 | 09:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
It will be okay for now, but you should get 4 matching tires and rotate them every 5K-6K miles, this will keep the tires lasting the longest, and keep wear even.
Old Feb 19, 2002 | 06:18 PM
willyb94's Avatar
New User
Default Re: If I have 205-50-15's up front, and 195-55's in the back, will it look wierd? (PatrickGSR94)
A lot of JDM guys do this. Look at the FF tuning video by Option. Lots of those guys are running 205/50/15 in front and 195/55/15 in the rear (road course) . If those guys are doing it then it must be good for something, right?
Old Feb 19, 2002 | 08:20 PM
Dee's Avatar
Dee
Default Re: If I have 205-50-15's up front, and 195-55's in the back, will it look wierd? (willyb94)
I run 215/50-15 in the front and 195/55-15 in the rear w/o any problems. Who gives a **** about the fashion police! Traction is SUPREME!!
[Modified by drealgsr, 7:41 AM 2/20/2002]
Old Feb 19, 2002 | 09:24 PM
Cheap Bastard's Avatar
New User
Default Re: If I have 205-50-15's up front, and 195-55's in the back, will it look wierd? (drealgsr)
I have done the same. 205 AVSi in front with stock 195 in back. The car rotates much easier. Great for autox.
Currently I have 205 Azenis in front and 205 712 in back. Similar effect. The Kumhos slide around turns. It really helps a front heavy, front wheel drive car without lsd to get around an autox track.
Also I like to buy 2 tires at a time. Easier on the pockets. Forget about rotating.
CB
Old Feb 20, 2002 | 05:58 AM
Community Builder
Default Re: If I have 205-50-15's up front, and 195-55's in the back, will it look wierd? (Cheap Bastard)
You would probably end up buying 4 tires, 2 at a time, in a shorter amount of time than if you rotated your tires and bought 4 at the same time.
Old Feb 20, 2002 | 08:36 AM
Vazquez911's Avatar
So is that the new fad in J-Land? Mismatched tire size?
Phew, 215s in the front... my 205s at full lock during autox rub.
Old Feb 20, 2002 | 05:38 PM
Dee's Avatar
Dee
Default Re: If I have 205-50-15's up front, and 195-55's in the back, will it look wierd? (Vazquez911)
fad? what fad? I did it because I had a set of soft tires and I wanted to get the widest tire possible on the front of the car. I guess I have the right combo of right height and wheel offset because I do not rub. Traction is delicious with the 215's!
Bigheadboy707
Jul 17, 2017 09:14 PM
Romo Pyro
Nov 5, 2009 02:49 PM
Gant
Mar 9, 2009 10:01 PM
deucedeuceEK
Mar 8, 2006 11:20 AM
