Can't lower 1/4 mile time using Skunk2 stage II
Old Jul 27, 2005 | 08:05 AM
gsl_05's Avatar
Default Can't lower 1/4 mile time using Skunk2 stage II
I am using a PnP, 3 angle b16 head, with Skunk 2 stage II cams, Skunk 2 springs and retainers, DC 4-2-1 header, 2.5 piping to the back, and slicks. I ran a 14.3 w crappy 2.2 60 ft. on slicks and a 14.6 on my street tires with my old setup(stock b16 head and CTR cams). The best time I can get now on the new setup is consistent 14.5. Are Skunk 2 II too much for a b16? Any information would help. Thanks in advance.
Old Jul 27, 2005 | 08:07 AM
K20DC2R's Avatar
Default Re: Can't lower 1/4 mile time using Skunk2 stage II (gsl_05)
how much power are you making?
Old Jul 27, 2005 | 08:18 AM
gsl_05's Avatar
Default Re: Can't lower 1/4 mile time using Skunk2 stage II (K20DC2R)
Maybe 170 to the wheel. People tell me I need more compression to run the Skunk 2 II's. I'm thinking of a b18 bottom end w/ CTR pistons?
Old Jul 27, 2005 | 08:28 AM
EK9 BEEZLER's Avatar
you could go b18 bottom end with ctr pistons but that would make your compression pretty high. why not just get ctr pistons and then mill the head as well as get a thinner headgasket.
Old Jul 27, 2005 | 08:32 AM
gsl_05's Avatar
Default Re: Can't lower 1/4 mile time using Skunk2 stage II (EK9 BEEZLER)
Head was already decked and I am using a .84 Cometic head gasket. I'm thinking of just throwing back in the CTR cams and run it from there. When I hit the 14.3 on slicks, I wasn't even trying. Now that I know how to run with slicks, I def. think I can hit high 13's.
Old Jul 27, 2005 | 08:34 AM
Y2K Si FBP's Avatar
have u ever tuned it? where is your vtec? u need like 6000+ with those cams. get it on the dyno then go back to the track
Old Jul 27, 2005 | 08:52 AM
PURPLETERROR aka BIGMATT's Avatar
Why are you using such a thick headgasket? First thing i would do is get rid of that garbage dc header, and invest in a good header such as anr, rmf, spark racing ect. And swap in an oem headgasket with the middle layer removed, depending on how much the head was shaved.
Old Jul 27, 2005 | 09:39 AM
harlesjohn's Avatar
have you got a dyno tune yet. if you didn't thats a must when u put a cam in your car. cams are so hard to get the right timing, but once you get a tune your should see like 14.1 maybe high 13s on your slicks. good luck
Old Jul 27, 2005 | 10:26 AM
JerseySiPOS's Avatar
Default Re: Can't lower 1/4 mile time using Skunk2 stage II (hondaharley)
you can't expect to run good times with those cams without tuning.
When i had my b16, after putting my Toda B cams in my b16, i went from
15.3 with 2.3 60 to a 14.3 with 2.3 60. just street tuning and manual datalogging. And of course i improved with driving. i experimented with cam timing, manifolds, throttle body sizes and shift points.
Oh, and i was using a CM stage 3 clutch with ACT 8 pound flywheel. Low trap speed though. Only 96-97 mph usually.
Old Jul 27, 2005 | 10:44 AM
thebigone05's Avatar
The Skunk2's are fine for the b16 you just need to get a better header with a 2.5" collector, a thinner headgasket i.e. shelf stock Cometic .030 thickness with a .5mm overbore, a good tuning session on the dyno and stiffer suspension. This will get you in the 13's no problem!!
If you are thinking about getting CTR pistons, then you should also think about the ITR pistons, they will yeild close to the same results and won't be such high compression!! You can also find the ITR's coated.
Old Jul 27, 2005 | 10:46 AM
Default Re: Can't lower 1/4 mile time using Skunk2 stage II (JerseySiPOS)
also, forget about running CTR pistons with those cams. I would rather have more valve to piston clearance to play with cam timing.
Plus with your setup, try advancing the intake cam with about 17 degrees ignition timing to start, stock injectors, and stock fuel pressure.
And if your revving to 9000 rpms or so, advancing the exhaust cam a crank degree or 2 might make more power in the 8000 rpm range for more area.
You can go to a tuner, or street tune and note your tuning changes before every track session.
Old Jul 27, 2005 | 12:13 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsl_05 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe 170 to the wheel. People tell me I need more compression to run the Skunk 2 II's. I'm thinking of a b18 bottom end w/ CTR pistons?</TD></TR></TABLE>
Classic!
"how much power you making?"
- reaches deep into the depths of his *** and removes a random figure
"maybe 170 to the wheels"...
Go put it on a dyno and at least tune the damn thing before you complain about what you did or did not gain.
Old Jul 27, 2005 | 01:14 PM
Default Re: Can't lower 1/4 mile time using Skunk2 stage II (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Classic!
Go put it on a dyno and at least tune the damn thing before you complain about what you did or did not gain.</TD></TR></TABLE>
yup, the only way i saw better results without going to the dyno is when i hooked up a wideband O2 and display. Other than that, playing blind gets you nowhere.
Old Jul 27, 2005 | 03:04 PM
gsl_05's Avatar
"Reaches into the depths of my ***"... huh? **** you bitch! Like its illegal to make guestimations. And you are the godfather of tuning? Kiss my a**
Old Jul 27, 2005 | 03:23 PM
rev limiter's Avatar
just remove that header and get soem tuning done, than you see where you stand but 13's are def. possible with that setup !!!
Old Jul 27, 2005 | 05:00 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsl_05 &raquo;</TD></TR><TR><TD CLASS="quote">"Reaches into the depths of my ***"... huh? **** you bitch! Like its illegal to make guestimations. And you are the godfather of tuning? Kiss my a**</TD></TR></TABLE>
I never came in here claiming to be the "godfather". Take your rice math somewhere else. How can you "guestimate" your damn hp to the gound?
header +20
stickers +30
intake +40
yep, I make 90hp over stock! fo sure!
Modified by Hybrid93Eg at 6:13 PM 7/27/2005
Old Jul 27, 2005 | 05:07 PM
Bunger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">I never came in here claiming to be the "godfather". Take your rice math somewhere else. How can you "gustimate" your damn hp to the gound?
header +20
stickers +30
intake +40
yep, I make 90hp over stock! fo sure!</TD></TR></TABLE>
DUDE... stickers are +25... not +30... some "godfather" of tuning you are.
Old Jul 27, 2005 | 08:40 PM
gsl_05's Avatar
Default Re: Can't lower 1/4 mile time using Skunk2 stage II (Bunger)
To Hybrid93Eg: I posted here looking for a little help from some guys who know more and have experience. I didn't post to get insulted by some smart a$$ lil $hit. Helpful comments appreciated and keep them coming.
Old Jul 27, 2005 | 09:11 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsl_05 &raquo;</TD></TR><TR><TD CLASS="quote">To Hybrid93Eg: I posted here looking for a little help from some guys who know more and have experience. I didn't post to get insulted by some smart a$$ lil $hit. Helpful comments appreciated and keep them coming. </TD></TR></TABLE>
If you think I am not "knowledgable" enough to help you and I don't have enough experience, so be it. Good luck.
B16A CRX
15
May 28, 2007 01:34 PM
BG-Teg
27
May 14, 2007 02:27 PM
si90rex
18
Dec 9, 2006 02:23 PM
lke2drvgsr
Feb 17, 2004 01:13 PM
lke2drvgsr
Feb 17, 2004 11:17 AM
