Magnaflow 3in to 3in CAT ??????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downeyballz »</TD></TR><TR><TD CLASS="quote">im running it and it works great</TD></TR></TABLE>
as am i
one big *** kat!
as am i
one big *** kat!
For oxygen to be sucked in by vacuum or a plug in from an air pump to increase burn to have cleaner emissions. 2 way cat is what its called think.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic »</TD></TR><TR><TD CLASS="quote">For oxygen to be sucked in by vacuum or a plug in from an air pump to increase burn to have cleaner emissions. 2 way cat is what its called think.</TD></TR></TABLE>
im guessing it has no affect on performance??
That is only for cars equipped with a SMOG pump. Cars stopped using those in the early 80's.
Chances are the specific cat you will want will either be 94009 or 94039. The 94039 is the same as the 94009 (3" OBDII/EPA compliant high flow) but has a bung for the aft O2 sensor if your car uses one.
fuckn crap i ordered the wrong one. changed it to the one without the airtube thing as i don't have anything to hook to it, also dont need any bungs on it either. its odb0 setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 »</TD></TR><TR><TD CLASS="quote">fuckn crap i ordered the wrong one. changed it to the one without the airtube thing as i don't have anything to hook to it, also dont need any bungs on it either. its odb0 setup.</TD></TR></TABLE>
i think even if you get the one with the little hose thing on it... you can stuff use it.. it should be ok... "i think"
j123crx
Aug 25, 2005 08:36 AM
yeegsr
11
Sep 12, 2004 01:19 AM
