missing at idle!?!?!?
Old Jul 27, 2005 | 05:40 AM
blowme's Avatar
Default missing at idle!?!?!?
Did a search and came back with plenty of results, the usual pcv valve cap rotor wires plugs and fuel filter. But my question to all of you is if the compression test came back good tryed all the other options what else. I came across someone in a search that had mentioned if you have cams that have a more aggressive lobe that may have effect on idle obd2 ecus pick that up as a misfire, when really it is not a misfire, that you would have to convert to obd1.
Just wanted to see some other feedback on that subject...
b16 head with valvetrain
s2s2 cams and gears
b18c1 block
underb00steg6
Jun 9, 2008 09:46 PM
FBPPrelude
Dec 27, 2006 07:12 PM
blowme
Jul 27, 2005 06:57 AM
bboy21385
18
Dec 4, 2004 05:39 AM
DubyaAye
Nov 29, 2004 10:37 PM
