b20b vtec piston myth...
Old Jul 26, 2005 | 08:36 PM
crazi92hb's Avatar
Default b20b vtec piston myth...
ok ive built ls/vtecs. and now its time to do a b20b/vtec. ive searched everywhere and half the people say the pistons wont clear the valves and the other half say they will. i kinda dont wanna experiment and break something. can someone help me.
Old Jul 26, 2005 | 08:39 PM
crazi92hb's Avatar
Default Re: b20b vtec piston myth... (crazi92hb)
any help????? gonna work on it tomarrow..
Old Jul 26, 2005 | 08:54 PM
IM ALL BOB's Avatar
using a standard b20b or z motor with a stock vtec head(that includes OEM type cams) will not cause any problems. As there is more than enough clearance for the valves and pistons. Just be sure to run either stock cam timing as advancing cam timing may cause problems with piston to valve clearance. Also just like LS/vtec don't rev beyond 8000 unless you replace rod bolts and other parts in the motor good luck
addl note: if you are concerned about piston-valve clearance you can clay the motor to check that, that would be the only other wayto verify if you will have problems
Modified by IM ALL BOB at 10:06 PM 7/26/2005
Old Jul 26, 2005 | 10:29 PM
crazi92hb's Avatar
Default Re: b20b vtec piston myth... (IM ALL BOB)
ok cool so all these guys i see cuttin the piston to make the valve relieves larger is really a waste of time.ive personally seen it but i always thought if you do this it would throw off the balance of the motor.
Old Jul 27, 2005 | 02:31 AM
Agent_STFU's Avatar
Banned
I would definitely not go hacking into my pistons. You should be fined with a near-stock setup.
Old Jul 27, 2005 | 02:39 AM
jdmeg9's Avatar
Default Re: b20b vtec piston myth... (Diseased Dreams)
i'vd done this swap and the b20b that i did it on had dish pistons in it so they cleared fine
crazi92hb
79
Aug 9, 2011 09:47 PM
willimo
Jan 22, 2010 11:32 AM
00siBuilder
19
Mar 24, 2004 01:28 PM
HotRodTeg
Apr 25, 2003 08:19 AM
mRvYbEs
Jan 29, 2003 10:58 AM
