just dynoed my built gsr
Old Jul 26, 2005 | 04:31 PM
itgsr98's Avatar
Default just dynoed my built gsr (opions plz)
just dynoed my gsr yesterday. im slightly dissapointed i thought i would see better numbers . tell me what you think. pull was done in forth gear.
setup:
m22's
rocket valvetrain/flat faced valves
usdm itr pistons
dtr b unit header
test pipe
rc 440 injectors
blox intake mani.
64mm throttle body
cold air inake
diy ported polished head/ port matched head to intake mani.
2 layer head gasket
vtec 5800
cut off 8300
tuned with s200
dynoed on dynapack
Modified by itgsr98 at 9:41 PM 7/26/2005
Modified by itgsr98 at 10:18 AM 7/27/2005
Old Jul 26, 2005 | 04:44 PM
rjay8604's Avatar
Default Re: just dynoed my built gsr (itgsr98)
I think you messed up the images tags, try redoing them so we can give you some feedback. nevermind looks like you fixed them.
Well yeah i agree, the numbers do seem low. I'm wondering why vtec doesn't seem to be providing the usual torque gain. What's the resulting compression ratio now?
Old Jul 26, 2005 | 05:02 PM
vinasity's Avatar
yeh numbers do seem to be kind of low
Old Jul 26, 2005 | 05:13 PM
itgsr98's Avatar
Default Re: (vinasity)
sorry just learning how to post images. also edited forgot one important and superior piece my dtr b unit header. imo
Old Jul 26, 2005 | 05:15 PM
itgsr98's Avatar
Default Re: (itgsr98)
compression some where around 11.5
Old Jul 26, 2005 | 05:34 PM
1heavy4dr's Avatar
the numbers are kinda low but take it to the track and time it. i remember my old set up similiar to yours but( ctr cams 11.1 cp)only made 158 hp to the wheeel @ Oshsimo and still ran a 14.4 on falken azenis in a fully interior dc2
Old Jul 26, 2005 | 05:42 PM
EK Josh's Avatar
How long have you had your m22/rm valvetrain? How do you like them with your setup? I'm trying to decide between those and the bc spec 3+.
Old Jul 26, 2005 | 06:17 PM
itgsr98's Avatar
Default Re: just dynoed my built gsr (GGhatchie)
well i thought the same thing when i first started my build over the winter bc3+ or m22. decided to go m22's for there good low/midrange power. they seem to be a good cam which is why i am disapointed on my #'s. not to mention it took 9 hours to tune and its still not right. the cams seem to be very picky. im actually trying find someone(in the east coast if anyone knows somebody) who may have better knowledge with the s200 tuning. ill be satisfied once i get the torque #'s up and the two dips in hp smoothed out.
Old Jul 26, 2005 | 06:24 PM
UncleD's Avatar
Obviously something isn't right. M22's are actually the least "picky" cam that you can get. I have them in my car and LOVE them, and as far as comparing them to a BC3+, they will DOMINATE them from 7k plus. I'm willing to bet any amount of money it's not the motor's fault, maybe an assembly air or something? Have you done a compression test? And cel's or anything?
Old Jul 26, 2005 | 06:32 PM
Hybrid96EK's Avatar
Default Re: just dynoed my built gsr (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Obviously something isn't right. M22's are actually the least "picky" cam that you can get. I have them in my car and LOVE them, and as far as comparing them to a BC3+, they will DOMINATE them from 7k plus. I'm willing to bet any amount of money it's not the motor's fault, maybe an assembly air or something? Have you done a compression test? And cel's or anything?</TD></TR></TABLE>
I'd bet money you are quite possibly wrong on the whole deal here. His setup is VERY similar to mine, and well, lets just say I was not impressed with M22's either. Here is the dyno, Skunk2 Stage 1's vs the M22's. You look at it and you tell me the M22's are better.
Just the facts here, not trying to bash anyone. This was done on the same dyno also, only things different between the two are the M22 cams, my own LIGHT cleanup of the head casting and a Hondata intake manifold. I tuned both, including the cam gears. These are the best results I could get.
Old Jul 26, 2005 | 06:59 PM
itgsr98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Obviously something isn't right. M22's are actually the least "picky" cam that you can get. I have them in my car and LOVE them, and as far as comparing them to a BC3+, they will DOMINATE them from 7k plus. I'm willing to bet any amount of money it's not the motor's fault, maybe an assembly air or something? Have you done a compression test? And cel's or anything?</TD></TR></TABLE>no cel. have not done leak down or compresion test but judging by the way the engine turns over by hand compression seems very good. car runs very well. pulls pretty hard through out the whole power band. no smoke, no oil consumption. im just disappointed with #'s. got to be something in the tuning. looking for someone else on the east coast to tune.
Old Jul 26, 2005 | 07:05 PM
itgsr98's Avatar
who else has dyno sheets with m22's. plz post
Old Jul 26, 2005 | 07:20 PM
stumpyf4's Avatar
Something is a miss... torque drops way off @4600rpm. Almost 15lbft drop from 4600rpm to 5100rpm.
How's the A/F ratio? This may give some hints on what is amiss.
Also are you absolutely sure that crossover is at 5800rpm?
Old Jul 26, 2005 | 07:28 PM
itgsr98's Avatar
Default Re: just dynoed my built gsr (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">Something is a miss... torque drops way off @4600rpm. Almost 15lbft drop from 4600rpm to 5100rpm.
Also are you absolutely sure that crossover is at 5800rpm?</TD></TR></TABLE> 13 to 13.5. thats actually what to took the longest out of the 9 hours of tuning trying to get the a/f readings within range. cam timing 3 degress advanced on intake. 2 degrees retarted on exhaust. yes vtec mapped for 5800.
Old Jul 26, 2005 | 07:43 PM
VtecKiDD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itgsr98 &raquo;</TD></TR><TR><TD CLASS="quote">who else has dyno sheets with m22's. plz post </TD></TR></TABLE>
One of my dynos, i cant find the 191whp one, ill look for it, i did over 100+dynos. This is my FIRST pull with b16a cams, the last is M22cams after tuning.
Gsr Block, PR3 Pitsons, B16 head , m22s, anr header, AEBS manifold
tuned with a VAFC
B16, STOCK BLOCK, STOCK HEAD, just M22s and a DC JDM 4-1 Header, AEBS manifold, Omnipower Valves
EDIT:**** , i forgot to switch it to SAE. well, subtract 3 whp from those numbers.
EDITx2: I also never even knew what my timing was at on the GSR CRX. I was tuning with a VAFC, and i had it at -25 in some spots. also i was dropping 12psi in fuel pressure in vtec cause my DX fuel pump was not up to the task. i never got to find out what it would have made with more fuel
Old Jul 26, 2005 | 08:05 PM
1Quikgsr's Avatar
thats way too low, find another tuner.. maybe you fucked up your head by the DIY port job
Old Jul 26, 2005 | 08:14 PM
VtecKiDD's Avatar
Default Re: (1Quikgsr)
as i was talking with some people before, EVERY motor is different, i cannot stress this enough. for some reason, my GSR and that B16 liked it REALLY lean, like 14:1+ lean. no detonation ever occurred. some of the M22s motors liked it rich. my suggestion is to put it at 13.5:1 and go lean and see if it makes power, but look at the WHOLE graph. and see what it does
I have to redyno the B16 cause his injectors were showing 106% duty cycle, so i got some H22s to put in. ill have more numbers posted this weekend.
Old Jul 26, 2005 | 08:50 PM
GOLDBERG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Quikgsr &raquo;</TD></TR><TR><TD CLASS="quote">thats way too low, find another tuner.. maybe you fucked up your head by the DIY port job </TD></TR></TABLE>
im thinkin it may be the DIY port job also..
problems it could be in no order
tuner
rings not seated yet(least likely)
diy port job..u can **** up a honda head big time if u dont know what yer doing
Old Jul 26, 2005 | 09:25 PM
hatchmobile's Avatar
Default Re: (GOLDBERG)
how did the cams do on 0,0??? i know rocket cams work very nicely w/out any adjustments
Old Jul 26, 2005 | 09:37 PM
UNKNOWN_MEMBER's Avatar
Default Re: just dynoed my built gsr (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> which is which, and if i recall, didn't you like your m22s?
Old Jul 26, 2005 | 09:47 PM
Hybrid96EK's Avatar
Default Re: just dynoed my built gsr (UNKNOWN_MEMBER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote"> which is which, and if i recall, didn't you like your m22s?</TD></TR></TABLE>
I have NO idea who you are so I don't know how you could "Recall" anything I said. The red line is the stage 1 skunks, blue is M22's. I thought that would be obvious.
Old Jul 26, 2005 | 10:10 PM
92TypeR's Avatar
FSAE
Two things I noticed.
A) The curve is very unhappy, it looks like the fuel trim is not very linear. Could just be the DynaPack also...
B) It seems to be peaking higher than the graph implies, so maybe there are more peak HP beyond what you were revving to.
Old Jul 26, 2005 | 10:16 PM
I have NO idea who you are so I don't know how you could "Recall" anything I said. The red line is the stage 1 skunks, blue is M22's. I thought that would be obvious.</TD></TR></TABLE> i was looking at threads for m22s and I think it was you who said they were happy with them. Or probably you guys had identical avatars.
Old Jul 26, 2005 | 10:27 PM
onepoint6i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">
tuner
diy port job..u can **** up a honda head big time if u dont know what yer doing</TD></TR></TABLE>
i agree!
Old Jul 26, 2005 | 10:43 PM
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote"> The red line is the stage 1 skunks, blue is M22's. I thought that would be obvious.</TD></TR></TABLE>
I want proof before I believe that dyno graph that you have posted above, or did you ever consider that that motor dyno'd wasn't "big" enough for M22's?? I think you may be jumpin to some conclusions here. If the creator of this thread wants, I can post NUMEROUS thread on how much power the M22's are making....
