wierd starting problem
Old Jul 26, 2005 | 02:56 PM
temp's Avatar
Default wierd starting problem
89 Si CRX, cranks strong but won't start. Not getting any spark, fuel is being supplied just fine.
replaced dizzy, and main relay.
any other ideas what it could be?
Old Jul 26, 2005 | 04:21 PM
jdeemseerx's Avatar
is it throwing any codes? is your timing right? if your not getting any spark then you know its from your dis back check your wires
Old Jul 26, 2005 | 04:25 PM
Eaglekper0046's Avatar
Default Re: (jdeemseerx)
Did you get a complete dizzy? or did you use the same coil?
Old Jul 27, 2005 | 07:29 AM
temp's Avatar
Default Re: (Eaglekper0046)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eaglekper0046 &raquo;</TD></TR><TR><TD CLASS="quote">Did you get a complete dizzy? or did you use the same coil?</TD></TR></TABLE>
complete remanned unit setup with the proper firing order. It throws a wierd code that no one seems to be able to deduce, it is 17 short consecutive blinks, not one long and 7 short. Code 17 is the VSS (if indeed that really is code 17 that i am getting) but the speedo works fine, all grounds are good. Could it be the ignition switch?
Old Jul 27, 2005 | 08:51 AM
DohcVtecCrx's Avatar
Default Re: (temp)
that is code 17 I told you that on the other thread
Your getting that code when you start it? That one will not come one until your moving. I think you might have gotten it a long time ago and never cleared it. Reset your ecu and see if it still shows up.
Old Jul 27, 2005 | 09:22 AM
temp's Avatar
Default Re: (DohcVtecCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcVtecCrx &raquo;</TD></TR><TR><TD CLASS="quote">that is code 17 I told you that on the other thread
it has been cleared numerous times still comes back, get it after driving around for a while, so how about the starting problem, ignition switch?
Old Jul 27, 2005 | 11:06 AM
Default Re: (temp)
if it cranks no not the switch.
You need spark, timing, fuel and compression for it to run. Start testing all these out and post back what you have found.
Old Jul 27, 2005 | 11:37 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DohcVtecCrx &raquo;</TD></TR><TR><TD CLASS="quote">if it cranks no not the switch.
You need spark, timing, fuel and compression for it to run. Start testing all these out and post back what you have found.</TD></TR></TABLE>
timing is fine 16 deg BDTC, fuel is fine, compression is fine 190 all across, its getting no spark.
VAAJ
36
May 7, 2009 07:35 PM
hybridpatient95
Oct 19, 2005 04:31 PM
mike93eh
36
Dec 18, 2004 01:18 PM
