weird question, does this exist? power outlet like wall socket for car?
yah, i know, odd question....
Okay lets see if ican clear upt he question. Do they make any adapters for cars to use electrical things liek a lamp for cars? Like how a lamp has the power plug that u plug into the wall. is there an item that exists to sue this "lamp" in the car.
Im not gonna use a lamp. but other things, like chargers for other batteries
is it possible, or do they exist?
they do exist. they are called d/c to a/c converters i think. it plugs into ur cig lighter.
[Modified by 01geeser, 9:43 AM 2/19/2002]
Yah exactly.. You can find these at bigger retail stores (like Walmart) and probably Kragen, Grand Auto, but I've never noticed them there..
Just keep in mind that u cannot use anything with a big draw (high amperage) like a fkn lawnmower or compressor, but smaller items like u mentioned (battery charger) or whatever.. All the specs are on the package showing you the type of things u can typically use..
[Modified by HKxBlur, 9:56 AM 2/19/2002]
THX for the quick replies
hmmmm, maybe ill strap a vcr and an external camera to ever corner of my car
its a thought
found it
42$ for this one at kragen
will these drain or damage my battery?
Edit: NM found these allover ebay for cheap
They are called dc to ac power inverters
[Modified by MintyDip, 2:28 AM 2/19/2002]
ive had one for a while in my car running my psx. try to pick up one thats 75w. that one is about a good all around energy source for almost anything you need and it wont suck up the battery that much. Mine works great, no problem. Picked it up from wal-mart for 24.95. and saw the same one at Radio Shack for 42.95. Stop by wal-mart and take a look ^_^
It's called a power inverter. Smaller ones you plug into the cig lighter. You can get larger ones but you should run them straight off the battery w/ large guage cable.
I've got one, picked it up at radio shack.
I can run a TV, VCR, and a battery charger on it at the same time.
Also, it will detect if the battery is getting too low and then shut it off, to prevent me from draining the battery.
I think it was about $30.
hope this helps.
-Brad
hope this helps.
-Brad
hope this helps.
-Brad
hope this helps.
-Brad
that really helps alot.
Would youhappen to have the model number on this?
sorry, no, i don't have a part #.
But i do know it's annodized blue, and they make several different models.
also, it only has one outlet, and i had to run a multiple outlet plug-in to run all the devices at once.
-Brad
-Brad
i have a small refrigerator that i bring on long road trips that i keep in the back of my car...uses that little box that you showed...its great for keeping drinks and other things cool on long drives so i dont have to stop at a 7-11 in the middle of nowhere.
that soudns KEWL!!!! Time to live in my car
BA5
11
Oct 31, 2005 09:45 AM
