unwise to bore a gsr block to 2.0L
Old Jul 26, 2005 | 02:30 PM
Finger Lickin' good's Avatar
Default unwise to bore a gsr block to 2.0L
looking to bore out my b18c1. Compression ratio of 11.6. Would the cylinder walls be to thin and crack...?
tried searching, unsucesisful
Old Jul 26, 2005 | 02:32 PM
Supernatural's Avatar
Default Re: unwise to bore a gsr block to 2.0L (D-CeReaL#4)
resleeve.....
rs machines
bensons
darton
golden eagle
google....gooday
Old Jul 26, 2005 | 02:36 PM
Default Re: unwise to bore a gsr block to 2.0L (SUPERNATURAL)
I know resleeving would solve the problem. Is it UNWISE to bore out a b18c1 to 2.0.
Old Jul 26, 2005 | 02:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-CeReaL#4 &raquo;</TD></TR><TR><TD CLASS="quote">I know resleeving would solve the problem. Is it UNWISE to bore out a b18c1 to 2.0. </TD></TR></TABLE>
**** yes
Old Jul 26, 2005 | 03:29 PM
anyone else?
Old Jul 26, 2005 | 03:33 PM
SkRiBLaH's Avatar
this is funny.
is it unwise to have more power?
sleeve your block. get new pistons. boom. you have 2.0L.
search the archives for more detailed info.
Old Jul 26, 2005 | 03:34 PM
91sihatch's Avatar
Yes it is STUPID
Old Jul 26, 2005 | 03:44 PM
Default Re: unwise to bore a gsr block to 2.0L (91sihatch)
k..what should I search for...Bored gsr, 2.0, didnt work to well....
Old Jul 26, 2005 | 03:52 PM
philafelman's Avatar
you can bore it...but you might not like the outcome without sleeving it. but hey, its your block and money, but i doubt you will find one person on this forum that will say its smart to do.
Old Jul 26, 2005 | 03:53 PM
no need for a cylinder brace thing right?
Old Jul 26, 2005 | 03:56 PM
CalhounBoi's Avatar
Default Re: unwise to bore a gsr block to 2.0L (philafelman)
Sounds smart to me
heh .....no way in hell I'd do it without sleeving first
Old Jul 26, 2005 | 04:38 PM
Default Re: unwise to bore a gsr block to 2.0L (CalhounBoi)
its my day off and did nothing but search and research...Seems like cylinerder wall braces are mainly for FI setups...
Is there actually enough pressuse in a NA 11.6:1 motor to NEED a cyliner brace. I look at ctr, itr, and theres no brace there.
Old Jul 26, 2005 | 04:40 PM
DonF's Avatar
Goes in the Darwin Award file. Listen to the posters.
Old Jul 26, 2005 | 04:45 PM
West Werks's Avatar
Default Re: unwise to bore a gsr block to 2.0L (DonF)
You cant get a 84mm bore on stock sleeves, which is needed to get to 2.0. So with that in mind if you want a 2.0 buy a b20 or sleeve your block. End of story.
no.... sleeving I understand... Im talking about those things thats like the brace at the top of the cylinder walls...looks like olympic rings...thought it was called cylinder brace?
Old Jul 26, 2005 | 04:49 PM
West Werks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-CeReaL#4 &raquo;</TD></TR><TR><TD CLASS="quote">no.... sleeving I understand... Im talking about those things thats like the brace at the top of the cylinder walls...looks like olympic rings...thought it was called cylinder brace?</TD></TR></TABLE>
They're not worth **** and will actually impede coolant flow to the cylinder head. So once again, you want a 2.0 b-series buy a b20 or sleeve it.
Old Jul 26, 2005 | 04:52 PM
b16sedan's Avatar
They're called a BLOCK GUARD, and are useless in basically any setup. I made over 400 WHP on stock B16 sleeves with no guard.
Old Jul 26, 2005 | 04:59 PM
Default Re: unwise to bore a gsr block to 2.0L (b16sedan)
thats what I thought.
Old Jul 26, 2005 | 05:03 PM
isnt there an ht sponsor that sleeves blocks out here in socal?
Old Jul 27, 2005 | 09:56 PM
Used2beAb16's Avatar
there is no way that u can get a gsr block to sleeve to 84 mm anyways, you will be running the bores into each other.
Old Jul 28, 2005 | 04:15 AM
Chillinit's Avatar
Default Re: unwise to bore a gsr block to 2.0L (Used2beAb16)
Listen to what people are telling you. Boring out a GSR to a 2.0L is not an option. Get it out of your head. You have to resleeve your block.
Old Jul 28, 2005 | 06:44 AM
West Werks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Used2beAb16 &raquo;</TD></TR><TR><TD CLASS="quote">there is no way that u can get a gsr block to sleeve to 84 mm anyways, you will be running the bores into each other. </TD></TR></TABLE>
Are you kidding me? You can up to 87mm bore on a B-series block. Very thin between the cylinders, but it is possible. 84mm is the standard on sleeve jobs for B-series.
Old Jul 30, 2005 | 08:52 AM
Default Re: unwise to bore a gsr block to 2.0L (VenGeanceDrag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VenGeanceDrag &raquo;</TD></TR><TR><TD CLASS="quote">
Are you kidding me? You can up to 87mm bore on a B-series block. Very thin between the cylinders, but it is possible. 84mm is the standard on sleeve jobs for B-series. </TD></TR></TABLE>
**** i meant on stock sleeves, of course u can go bigger if u re-sleeved.
Old Jul 30, 2005 | 09:41 AM
johnzm's Avatar
**** it!!
hey man, SERIOUSLY u can do this.
i mean hell if it does blow, u at least already haev the 84mm pistons, and everything setup fo the bore.
just bore the stock ones out, and have the cash set aside to sleeve it, when it blows.
just KEEP US UPDATED
Old Jul 30, 2005 | 10:25 AM
Grand's Avatar
84mm bore stock sleeve gsr + 8100rpm = cracked sleeves and a waste of time and money. HAVE IT SLEEVED
