a/c problem
my a/c has pretty much stopped working in my 91 crx dx, when i have it all the way up it barely blows at all, also it does this when i have the heater on, wondering if any of you guys could help me out, thanks advance.
Could be a few things, it might need a recharge though, or the orifice tube went bad.
All depends though, is it blowing out hot air, or is it blowing out cold air and its just weak ?
Modified by 90blackcrx at 6:17 PM 7/26/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_si6 »</TD></TR><TR><TD CLASS="quote">my a/c has pretty much stopped working in my 91 crx dx, when i have it all the way up it barely blows at all, also it does this when i have the heater on, wondering if any of you guys could help me out, thanks advance.</TD></TR></TABLE>
You mean the air that actually comes out of the vent is weak, whether its on cold or hot? Kinda sounds like the blower motor is on its way out.
when you take your glovebox out and look at the top of your blower motor unit you should see a plug on top of it take that plug out and the two screws holding the resistor in..see if the resisitor is broken, if one of the coils is shot it will only blow at a certain speed if all is well then you know its def your blower motor that needs to be cleaned
JDM-EJ1
17
Sep 5, 2019 11:51 PM
preludesi93-arg
Dec 29, 2006 02:49 PM
