Del Sol problems....
Old Jul 26, 2005 | 02:00 PM
pythoner's Avatar
Default Del Sol problems....
Ok i have a 95 del sol SI and i have a couple of Q's that i can't find...
First the electric lock aren't working, you can hear them accuate but they won't lock....
Second how do you get those door panels off, I have taken every bolt I have found and it won't go in any direction.
And last has anyone found a good fitting body kit? I havn't seen on that just bolted up like they do for other cars.
Thanks
Old Jul 26, 2005 | 02:11 PM
BlueIntegraBoy's Avatar
Default Re: Del Sol problems.... (pythoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner &raquo;</TD></TR><TR><TD CLASS="quote">
There are usually ones behind your door handle, door pocket (things to close the door), and it's held on by clips. Pull on it.
Old Jul 26, 2005 | 03:36 PM
vsmhatched's Avatar
Default Re: Del Sol problems.... (BlueIntegraBoy)
bolting on a body kit with no modifications made to it, I've never heard of such a thing. Body kits aren't the greatest thing in the world. BUt its your car, but i thikn its gonna be very hard to get or find a kit that is going to just bolt up.
Old Jul 26, 2005 | 06:56 PM
nocturnaldragon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner &raquo;</TD></TR><TR><TD CLASS="quote">First the electric lock aren't working, you can hear them accuate but they won't lock....</TD></TR></TABLE>
Remove the door panels and the locks themselves, to get the locks off remove the linkage and the three hefty screws holding them in. BTW the linkage can be a bitch just to warn you.
Once its all out clean the thing out and re-grease all the moving parts particularly the white plastic ones. (You'll see what I mean) Now hook it up to a power supply outside of the car before you put it back in and it should be locking like a champ. (Much better then the $245 replacement module I think)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner &raquo;</TD></TR><TR><TD CLASS="quote">Second how do you get those door panels off, I have taken every bolt I have found and it won't go in any direction.Thanks</TD></TR></TABLE>
You have to pop the cover off from behind the door handle itself and in there, theres a screw holding it in. From there there is like one push-screw connector by the sail window. Then just pull theres some clips on the bottem you get off by just yanking on the bottem of the panel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner &raquo;</TD></TR><TR><TD CLASS="quote">Thanks</TD></TR></TABLE>
Yourwelcome.
fast6fan
Jan 17, 2018 11:36 AM
xboxhaxorz
Paint and Body
Nov 30, 2007 06:06 PM
PinoyDelSol
Nov 10, 2007 12:11 AM
toben
Feb 24, 2007 08:05 PM
