1987 Accord LX (carbed) - Any way to go fuel injected without it costing an arm/leg?
Old Jul 26, 2005 | 01:36 PM
BoostdRex's Avatar
Default 1987 Accord LX (carbed) - Any way to go fuel injected without it costing an arm/leg?
Is there any way to go fuel injected on a 1987 Accord LX (carbed) without having to swap to a completely different motor that requires motor mounts, etc etc?
I know D-Series motors, but not familiar with A-Series motors... Please lend a hand?
I know it will require ECU, harness, injectors, etc etc... (have done many DPFI - MPFI swaps on my CRX, but never A-Series...)
Old Jul 26, 2005 | 01:55 PM
Vanilla Sky's Avatar
i'd assume it would be like the civic EFI swap. there's a how-to on http://www.3geez.com on this. go over there and find all the info you're ever going to need about your 3gee.
Old Jul 26, 2005 | 02:51 PM
P_Adams's Avatar
Default Re: 1987 Accord LX (carbed) - Any way to go fuel injected without it costing an arm/leg? (BoostdRex)
If I were to attempt this, I'd buy an '88 LXi parts car for 200$ and swap everything over.
But why go that route when you can pick up an LXi (inspected) for probably 500$ to 800$ and save yourself all that &^*&%$$# cursing.
Modified by P_Adams at 5:27 AM 7/27/2005
Old Jul 26, 2005 | 07:56 PM
BoostdRex's Avatar
Default Re: 1987 Accord LX (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">If I were to attempt this, I'd buy an '88 LXi parts car for 200$ and swap everything over.
But why go that route when you can pike up an LXi (inspected) for probably 500$ to 800$ and save yourself all that &^*&%$$# cursing.</TD></TR></TABLE>
Haha, well, it's not my car. It's my friend's fiance's car...
Are the '88's engines interchangeable with the '87 and it's tranny? Thought it was a different series motor...
Old Jul 26, 2005 | 08:27 PM
P_Adams's Avatar
Default Re: 1987 Accord LX (BoostdRex)
I believe they are both F20's (2.0 Litre). Changing over to EFI will be a daunting task 'cuz you'd have to change out all but the engine long assembly, and trans. Differences include intake manifold with all related components, distributor, all wiring, engine control modules, vacume harnesses and vapor control systems. On top of this you have to change out the fuel pump.
In effect, you end up gutting half the vehicle just getting to the required changes.
P
Old Jul 26, 2005 | 10:53 PM
philadd's Avatar
The motors are both A20's.
Write up for EFI conversion:
http://www.geocities.com/carot...n.htm
Old Jul 26, 2005 | 11:03 PM
BoostdRex's Avatar
Default Re: 1987 Accord LX (philadd)
Ok, I was sure they were A-Series motors... Well, at least the '87...
Old Jul 26, 2005 | 11:06 PM
philadd's Avatar
I should mention that there ARE some slight differences between the 86-87 motor and the 88-89 motor. I don't remember the details, but you can probably find your answers on 3geez.com
Old Jul 26, 2005 | 11:32 PM
BoostdRex's Avatar
Awesome, thanks guys., I'll look it over and if I get stuck, I will holla at ya guys!
Old Jul 27, 2005 | 05:03 AM
cams and pistons are the only differences. the 86/7 was supposed to have had a better cam, and the 88/9 has higher compression. the carbed motors remained unchanged.
Old Jul 27, 2005 | 07:20 AM
BoostdRex's Avatar
Default Re: (Vanilla Sky)
I guess my question had to do with going to a fuel injected set-up. What intake manifolds and distributors will fit that head in order to do so? (I know how to do the rest such as ecu, harness, etc etc... Done them on Civics)
Old Jul 27, 2005 | 08:27 AM
just get the stuff from an accord LXi or SEi of the same year and you'll be fine.
Old Jul 27, 2005 | 08:38 AM
BoostdRex's Avatar
Ok, thanks...
mantishi
Jan 16, 2007 04:16 PM
drivewaytuner
Dec 6, 2004 04:46 AM
phazed86
Apr 13, 2004 12:15 PM
flemo
Jul 13, 2003 01:59 PM
